G-Ultimate3 Jun 2011 22:21Hello everyone,
I have the following issue. I have two rooms, both with laminate flooring. At the doorway, there is quite a high height difference (about 4 cm (1.6 inches)), so I cannot use a transition strip since they usually only accommodate up to 2 cm (0.8 inches) difference.
What options do I have to create a proper transition between the two rooms? In addition, the laminate at the doorway is not cut very neatly because I assumed a transition strip would cover it.
I would appreciate any tips.
