ᐅ Height adjustment on wooden mezzanine
Created on: 12 Dec 2024 00:06
Flitz86
Flitz86
12 Dec 2024 00:06
Hi, we have installed a mezzanine in our living room. The base of the mezzanine consists of three-layer panels that rest directly on the joists.
Now, since we need some lighting beneath the mezzanine, we want to run the cables over the mezzanine floor so that the cables are not visible.
These are several 5x1.5 NYM cables, which have a thickness of about 1 cm (0.4 inches).
We are wondering how we can even out this height difference. Ultimately, laminate or cork flooring will be installed.
Using a leveling compound is not really an option for me.
Are there any types of panels that could be laid for this purpose?
Chris
ateliersiegel13 Dec 2024 16:42
Flitz86 schrieb:
The base of the gallery is made of three-layer boards
How about "routing slots"? Usually, these boards are at least 28mm (1.1 inches) thick. That would provide enough space for a 10mm (0.4 inch) thick cable (aren’t they actually not that thick?). The cables usually only run a short distance and not from one wall to the other, so in my opinion, this wouldn’t be a problem for the stability.
Nida35a13 Dec 2024 20:12
Flitz86 schrieb:
It’s about several 5x1.5 NYM cables – so they add up to about 1cm (0.4 inches) in thickness.
Rewire onto a flat cable, which will be thinner and you won’t need to cut grooves as deep.
Flitz86
13 Dec 2024 20:19
ateliersiegel schrieb:
How about "milling grooves"? Usually, these panels are at least 28mm (1.1 inches) thick. That would easily leave enough space for a 10mm (0.4 inches) thick cable (aren’t they usually not that thick?)
That was my first thought as well. But there are quite a few cables, so I would prefer an alternative. At least it would be good if I don't have to lay all the cables entirely under the floor and maybe only need to compensate for half of them.
The panels are 30mm (1.2 inches) thick.
Flitz86
13 Dec 2024 20:21
Nida35a schrieb:
rewiring to a flat cable, which is flatter and means you don’t have to rout the channels as deep
Do you have a specific suggestion?
I have only found riser cables. But those are generally no longer used today or are not suitable for installation on wood.
