ᐅ Height adjustment between tiles and laminate flooring
Created on: 29 Oct 2020 08:25
Freedark
We have tiles and laminate flooring installed on our ground floor. Unfortunately, no appropriate transition profiles were used at the time. This has become increasingly bothersome. The height difference is about 9mm (0.35 inches). Drilling is not an option because there is underfloor heating installed.
I am considering a profile that could be glued onto both types of flooring. The hardware store couldn’t really help me, and I didn’t find much through online searches either.
Can anyone offer advice or assistance?
Door threshold: transition from gray tiles to wood-colored flooring with metal edge.
Tolentino4 Nov 2020 23:37
Thank you for your response, but then it is not traditional laminate flooring, but rather vinyl flooring.
X
X_SH5_X
18 Nov 2020 14:07
How about using a type of wedge strip like the one shown in the attachment (it’s probably available in other colors as well)? You could use that to even out the height difference. Whether it actually looks good, I can’t say. However, I would probably find an edge like yours, where you keep stubbing your feet, quite annoying. Or maybe a kind of curved profile that you stick over the edge?! It might not be very attractive, but it could be worth trying.
Grau gestreiftes Metall-Dachblech als Wellblech-Dachpaneel
Silbernes Metallblech in Perspektive, glatte Oberfläche, abgerundete Kante
Steffi33
19 Nov 2020 13:16
I would glue a quarter-round profile made of black PVC with a height of 8mm (0.3 inches). Simply saw off the “overhang” beforehand.
Bookstar
19 Nov 2020 19:59
Laminate floating? Just place impact sound insulation mats underneath up to the height of the tiles. Otherwise, I would install a small transition strip.
It can’t stay as it is. That’s actually dangerous! (Toe hurts)
Freedark
25 Nov 2020 18:10
Thank you for your ideas.
I will try to find something suitable.
X
X_SH5_X
29 Jan 2021 11:09
Freedark schrieb:
Thanks for your ideas.
What happened with all that? I’d be interested to know. We have a similar spot between our kitchen and dining area. We also tried impact sound insulation there. It’s not perfect though, because you can feel that you step up slightly by about 1–1.5m (3–5 feet).
