ᐅ Heating a room in the basement
Created on: 24 Sep 2013 09:20
bergbau-1
24 Sep 2013 09:20
Hello everyone
We have a separate, lockable room in our basement without heating, which we have renovated this year to serve as a children’s playroom. Now the cold season is approaching, and the room needs to be heated somewhat. So far, the temperature during winter has been just around 10°C (50°F).
The room is approximately 3.5 x 5.5 m (11.5 x 18 ft), about 20 m² (215 sq ft), and it should be heated quickly and on demand. I have looked into infrared heaters and warm air blowers. The downside of infrared is the purchase cost, especially since the room probably won’t be used daily; the advantage is the comfortable warmth it provides.
Does anyone have additional suggestions on the best way to quickly warm up this room?
Thanks a lot for your tips
Regards, René
Richard-1
7 Feb 2014 10:26
Hello Bergbau
The main drawback of infrared heating is the high initial investment cost. A radiator could also be an option, although energy costs tend to be high as well. Another good alternative would be a gas-powered heater.
Jonas-1
30 Mar 2014 10:27
The previous poster has already mentioned several points. Electric heaters are not an option for me because the costs are simply too high. I can well imagine using a gas-powered heater. Alternatively, you could connect the basement to an existing heating system.
Kaminofen-Lui-1
9 Apr 2014 18:57
I have serious concerns about using a gas-powered heater in a basement room – fresh air, meaning breathable air, must be supplied at all times; otherwise, it can be very dangerous! The exhaust gas containing CO2 and water vapor makes the indoor climate unbearable.
Annegret-1
16 Apr 2014 06:57
A gas-powered heater like that is simply not suitable for a basement. There is a lack of the necessary fresh air supply. This can be life-threatening, especially for children.
Nicole1981-1
10 May 2014 11:24
We faced the same issue and diverted a pipe from the boiler return line to install a suitable radiator in the room. In my opinion, this is a good solution.
