ᐅ Has anyone managed to make scratches in the white surface of a KALLAX unit "invisible" again?
Created on: 6 Oct 2024 09:37
U
Usro1Hello everyone,
I recently purchased a white KALLAX shelf unit from IKEA and unfortunately have already noticed some scratches on the surface. These marks are especially visible on the white areas and make the furniture look quite worn. I’m wondering if anyone here in the forum has experience with making these scratches in white lacquer or melamine “invisible” again?
I’m looking for a method or product that is specifically suitable for this type of surface, without damaging the color or gloss underneath. Does anyone have tips on whether this can be fixed with home remedies, special repair kits, or perhaps a touch-up pen?
Looking forward to your advice and experiences!
Hello Usro1,
I’m familiar with the issue of scratches on white KALLAX surfaces. Most of them are actually melamine-coated, which makes repairs a bit tricky since you can’t simply repaint the surface.
A well-proven method is to first gently smooth the scratches with a fine sanding pad. Important: work very carefully and don’t sand too deeply, otherwise the scratches may become even more noticeable.
After that, you can use special furniture repair fillers or white wax sticks designed specifically for melamine surfaces. The wax sticks can be easily applied to the scratch and then polished with a soft cloth.
Sometimes a white paint pen can also help, but the result is usually somewhat dull because the paint rarely matches the original color and surface finish exactly.
If you want to try it, I would recommend testing on an inconspicuous spot before treating the rest of the surfaces. If you like, I can also provide product names.
I hope this helps you for now!
Kinbu schrieb:
Most of them are actually melamine-coated, which makes repairs a bit tricky because you can’t simply repaint the surface.That is correct. Melamine coating is very durable but also prone to scratches that cannot be fixed with regular paint.
To remove or minimize scratches, I recommend:
1. Cleaning the area with a mild detergent to remove dust and dirt.
2. Lightly sanding with a very fine abrasive pad (e.g., 2000 grit), only if the scratch is not too deep.
3. Using a color-matched furniture repair wax or repair stick—especially designed for white surfaces.
Note: Wear marks can usually only be disguised; they rarely become completely invisible.
Alternatively, you can try refreshing the surface slightly with some white furniture polish or silicone oil, which can help to subtly conceal minor scratches.
I think the whole scratch discussion about KALLAX is overrated. Sure, the surface scratches easily – it’s an affordable piece of furniture, not a designer item. If you want flawless surfaces, you might want to choose solid wood or high-quality finishes instead.
The truth is: it rarely becomes invisible, at best it’s concealed. I’ve tried wax sticks, but you can still see them if you look closely. So: don’t spend too much time on it, better to cover it up or hide it with a decorative element.
Usro1 schrieb:
Has anyone had experience with making scratches in the white paint or melamine on KALLAX “invisible” again?
Hey Usro1,
I also had scratches on my white KALLAX and had great results using white furniture wax! 🙂 Just apply it to the scratched area and then gently polish it – this enhances the white color and fills in the scratches, making them nearly invisible from a certain distance. Really clever if you don’t want to do a full repaint!
In case you haven’t tried it yet: look for "white furniture wax" or "white furniture repair pen." You can find these at most hardware stores.
Good luck – it’ll be fine! 🙂
