ᐅ Has anyone ever replaced the back panel of a KALLAX unit with plywood?
Created on: 30 Oct 2024 19:07
GusutraHello everyone, I have a question for those of you who have replaced the original thin back panel of an IKEA KALLAX shelf unit with a plywood back panel.
Has anyone completed a project like this? I am especially interested in how the stability is affected, whether the back panel can be easily cut to size, and if the plywood warps or causes any issues once installed.
Also, what thickness of plywood did you use, and how did you attach it without damaging the side panels too much?
I imagine this modification would make the shelf significantly more stable, but I’m unsure if there are any drawbacks. Looking forward to your experiences and advice!
Gusutra schrieb:
I’m especially interested in how the stability changes as a resultOh yes, it’s fantastic that you’re taking this on! I once reinforced my KALLAX with 6 mm (1/4 inch) plywood and can say: the stability increases significantly, the shelf becomes very rigid, almost like a small piece of furniture on steroids! :-)
Gusutra schrieb:
What thickness of plywood did you use, and how did you attach it?I used 6 mm (1/4 inch), which is nice and sturdy but still easy to work with and not too heavy. For fastening, I used small screws with pre-drilled holes, which worked really well without any splitting. I also used wood glue to secure everything firmly.
If you’re interested, I can also share some tips for cutting – you really can’t go wrong with them! 🙂
I would like to explore this topic in more detail because, when making such modifications, it is important to me not only to find a short-term solution but also to focus on durability and build quality.
If you remove the original back panel, the KALLAX unit is indeed less resistant to twisting – the thin particleboard of the back panel plays an important role here. Plywood is much more stable against warping, although it greatly depends on the type of wood and especially the wood moisture content. In practice, many use 6mm (1/4 inch) multiplex plywood because it offers very good strength at a comparatively low weight.
Carefully pre-drilling the screw holes is absolutely necessary to avoid splitting the material. Something I often see: screws that are too thick and no pilot holes – this leads to the fastening opening up in thin plywood. It is best to use countersunk screws so they sit flush.
From my experience, the plywood panel should be treated with a suitable surface finish (e.g., wood oil or varnish) before installation to prevent swelling and warping due to moisture – this can easily happen in living spaces with varying humidity.
I’m interested to know if your KALLAX will be heavily loaded? If so, you should also consider additional reinforcements at the corners, such as small metal brackets or wooden strips. This increases overall stability and prevents the shelf from bowing out at the back over time.
What size is your KALLAX, and have you already completely disassembled it for the modification?
Filippo schrieb:
I’m curious if your KALLAX is heavily loaded?Great that you bring this up! In my case, the shelf is mostly in the living room for books and decorations, so it’s moderately loaded. Even then, the plywood back panel makes it significantly more sturdy.
Filippo schrieb:
treat the plywood with a suitable surface finish before installationI can definitely recommend that too; I oiled it and haven’t seen any warping for months. It also gives the shelf a much more premium look – almost a DIY designer touch 😉
If anyone is planning to take the shelf apart completely: Removing the original back panel worked well for me using a cordless drill and some gentle prying. Just be careful loosening the screws, otherwise it may splinter.
