ᐅ Has anyone ever covered a KALLAX shelving unit with furniture vinyl wrap?
Created on: 2 Aug 2022 10:17
ArianteoHello everyone,
has anyone here ever fully covered an IKEA KALLAX shelf unit with furniture film? I'm particularly interested in how well the film adheres to the relatively rough, melamine-coated particleboard material and whether there were any issues with air bubbles or edges when cutting and applying it.
I want to slightly increase the depth of my KALLAX and customize the color, but I’m unsure if furniture film is a truly practical alternative to paint or other surface finishes. It would also be helpful to know if the film tends to peel off or get damaged with frequent use.
If you have any tips on adhesion, tools, surface preparation, or handling, please share. Thanks in advance!
Arianteo schrieb:
I’m especially interested in how well the film adheres to the relatively rough, melamine-coated chipboard materialHello Arianteo! I did exactly that – covered a KALLAX with furniture film – and I’m absolutely thrilled! 🙂
The film is really easy to apply if you clean and dust the surface thoroughly beforehand. I used a squeegee – a flat plastic tool – to smooth it out and avoid bubbles. You do have to be careful at first, but once you get the hang of it, it almost feels like a DIY game!
As for durability: I haven’t noticed any wear after 8 months, even though the shelf gets frequent use. The film is quite sturdy and also resists moisture if you accidentally spill something.
The only tricky part is the edges, since the film tends to lift there. That’s why I made small cuts at the corners, which helped a lot. So go for the film – it’s fantastic!!!
Davidleo schrieb:
The film is quite durableDavidleo, it’s interesting that you find the film to be durable. However, there are different quality levels of furniture film, and some brands tend to peel or warp more quickly, especially when exposed to UV light.
Furthermore, the original KALLAX material structure is not designed to resist moisture – which with some films increases the risk of edges lifting over time or dirt accumulating under the film.
I would really be interested to know if you have any long-term experience or evidence on how such a film performs over several years. I also think a comparison with other methods, such as painting or laminating, would be helpful to better weigh the pros and cons.
I also applied a foil finish to the Kallax. Important: clean the surface thoroughly, making sure it is free of dust and grease.
When cutting, take precise measurements; it’s better to cut slightly smaller than too large.
Use a fine heat gun to smooth the edges.
It holds well if you work carefully.
Arianteo schrieb:
I am particularly interested in how well the film adheres to the relatively rough, melamine-coated particleboard material.In my opinion, this whole craze about adhesive films for furniture is greatly overrated. If you want to upgrade your KALLAX, it’s better to consider higher-quality surfaces rather than cheap adhesive films that tend to peel off after about a year of heavy use.
I think many people simply underestimate how much wear and tear a shelf really undergoes in everyday use. These old films are hard to clean, they tear at the edges, and quickly become brittle.
If you really want a visual change, it’s better to paint or order new front panels. For me, adhesive film is more suitable for short-term decoration, not as a long-term quality replacement.
