ᐅ Hairline cracks in lime-cement plaster
Created on: 3 Mar 2019 17:03
blaupuma
Hello to the few who have plastered their living areas with cement-lime mortar.
The painter is ready to start and noticed that we often have hairline cracks in the plaster. The plan was just to sand the plaster (this has already been done) and apply two coats of paint. We would prefer not to fully skim coat the surfaces.
Has anyone experienced the same issue?
This is not considered a defect; we knew we were doing something a bit unusual.
Close-up of a gray concrete surface with cracks and slight texture.
blaupuma3 Mar 2019 19:14
The cracks appeared overnight.
The plastering was done exactly 8 weeks ago.
Nordlys
3 Mar 2019 20:03
Setting refers to the chemical process in which cement and water form cement paste and subsequently cement stone. This process releases heat, known as hydration heat or setting heat. In short, as the setting progresses, the concrete becomes harder.
If the water evaporates too quickly, it disrupts the setting process, causing volume changes, shrinkage, and cracks. Therefore, with screed and plaster, do not ventilate immediately; instead, allow the moisture to remain inside the building initially.
blaupuma3 Mar 2019 20:19
Nordlys schrieb:
Curing refers to the chemical process in which cement and water form cement paste and subsequently cement stone. This process releases heat, known as hydration or curing heat. In short, as curing progresses, the concrete becomes harder.
If the water dries out too quickly, it disrupts the curing process, causes volume changes, shrinkage, and cracks. Therefore, for screed and plaster, do not ventilate immediately; instead, allow the moisture to remain inside the building for a while.
Okay, then I have to live with that.
I just want to be sure that the plaster is not hollow and is firmly bonded to the Ytong blocks.
Is tapping enough, or is there a trick to check this?
The contractor says everything is fine, but I would still like to verify it myself.
Replacing it would be a disaster.
