the title says it all. We are currently planning the electrical system for our new build.
The electrician has planned a Hager “technical center” with a multimedia panel. This is where the LAN cables will terminate. Additionally, I would like to install the router and a NAS (Synology 214play) there.
It looks quite neat and seems to fit everything needed, but does this make sense?
Today, I was wondering why I wasn’t offered a server cabinet.
What are your experiences? What makes more sense? How does it affect the cost?
I would be very grateful for some advice.
Christian
Christian
Daniel-Sp17 Aug 2021 17:52Faster and better is always possible, but not always necessary.
Currently, only the Wi-Fi devices (mobile phones) in my setup are being limited by the maximum possible Wi-Fi throughput. The rest of the network runs with the current configuration using the SG 300 in Layer 3, performing no worse than when the SG 300 was configured as a simple switch without routing. If you truly need much more performance, there are of course better devices available, but also at a “better” price. You can find an SG 300 for a low price on classified ads, often even with PoE...
We are still talking about a small home network here; the SG 300 provides plenty of power for this and can handle more and larger setups, although exceptions always prove the rule.
Daniel-Sp schrieb:
Faster and better is always possible. But it’s not always necessary.That’s true, but with the SG300 we’re talking about less than 100 Mbit/s routing speed. That’s slow even for private households. My point, however, is just to avoid the belief that a typical small business routing switch alone provides a good solution once you’re dealing with multiple subnets.D
Daniel-Sp17 Aug 2021 18:15Only static routes (I need more characters)
