ᐅ Grout Color for Floor Tiles at Wall Junction
Created on: 10 Jul 2019 08:00
benutzer 1004
We are currently planning to install floor tiles (gray/"moon" porcelain stoneware with a subtle concrete look) on the walls as well, at least in the guest bathroom. We have two questions and would appreciate your opinions:
- The floor tiles will be 60x60cm (24x24 inches). Should the wall tiles be 30x60cm (12x24 inches) or also 60x60cm (24x24 inches)?
- The default grout color is silver gray for the walls and cement gray for the floor. Is this common practice even when using the same tiles (as we have been told), or do people usually use the same grout color for both? If so, which one? Should it be darker or lighter than the tile?
Thanks and best regards
benutzer 1004
11 Jul 2019 14:22
Zaba12 schrieb:
For what purpose? For the baseboard or for the grout lines?
Here, it’s done according to the customer’s preference. My tile installer sets the baseboard height at 7cm (3 inches). We wanted 6cm (2.4 inches). He had customers who wanted 10cm (4 inches).
Grout lines vary depending on the tile. For rectified tiles, 2–3mm (0.08–0.12 inches) is typical and also the minimum.
No, I meant for 60cm by 60cm (24 inches by 24 inches) floor tiles. Would you use 60cm by 60cm (24 inches by 24 inches) tiles on the wall as well, or rather 30cm by 60cm (12 inches by 24 inches)?
borderpuschl
11 Jul 2019 15:13
What types of flooring do you usually use? Have you ever considered using the same tile for both the floor and walls in the guest bathroom? This way, you avoid grout lines except for the silicone seals in the corners.
hemali2003
11 Jul 2019 15:49
Curly schrieb:
We have concrete-effect tiles on the bathroom floor and walls. We chose the grout color ourselves and had the floor and walls grouted with the same color, because in my opinion it doesn’t look as good otherwise (with the same tiles).
Sabine
How new is that for you? In our case, the floor grout has darkened slightly after 1.5 years. But it’s not really bothersome.
benutzer 1004
11 Jul 2019 17:23
borderpuschl schrieb:
What kind of floors do you have otherwise?
Have you ever considered using the same tile for both the floor and walls in the guest bathroom? That way, you avoid grout lines except for the silicone joints in the corners.
What do you mean by "using the same tile"?
The floor and walls in the bathrooms are supposed to have the same tile, which comes in two sizes. 30cm x 60cm (12in x 24in) is of course a bit cheaper, and some friends said that it also looks better to have the larger tiles on the floor and the smaller ones on the walls.
