the development plan applicable to our construction project requires a green flat roof. However, we would also like to install a photovoltaic system on the roof. The building site is in Hesse. A preliminary online search combining these two terms showed that they do not necessarily exclude each other.
Are there any experiences or tips regarding the permits, or is this a hopeless endeavor?
Best regards!
Best regards!
Thank you all for the many responses! They have already helped me a lot.
I understand that the most reliable answer can only come from the building authority, but I still find it quite helpful to hear from anyone here who has experience with this.
The problem is that the architect believes photovoltaic and green roofing are mutually exclusive. Before I go straight to the building authority based on my amateur Google research, which suggests otherwise, I just wanted to check if anyone here has dealt with this issue before.
In fact, aerial images are analyzed here in the district. A neighbor was inspected on site as a result.
I actually don’t want to avoid the green roof regulation. I think a green roof is a great idea and would like to combine both. Based on the feedback here, I will pursue this further. Thank you all!
Müllerin schrieb:
what’s the problem now?
Do an extensive green roof with sedum plants, it works under elevated modules too, there are varieties that can tolerate it.
Then you get both.
bortel schrieb:
Elevate, install photovoltaic modules, add some substrate around, done...
I wouldn’t ask anyone and would just build it without the green roof. Who would come to check your flat roof with a ladder?
quisel schrieb:
The problem is that the architect thinks photovoltaic systems and green roofs are mutually exclusive.Well, even with an extensive green roof, it’s definitely a good idea to check more frequently whether the vegetation is becoming too dense.
quisel schrieb:
In fact, aerial images are analyzed here in the district.And then you see a photovoltaic system on your roof with the green roof surrounding it. But who looks underneath the photovoltaic panels?
guckuck2 schrieb:
Well, even with an extensive green roof, it’s definitely a good idea to check more frequently whether the vegetation is getting out of hand. We are definitely keeping an eye on that as well. However, overall, I consider it less of an issue.
guckuck2 schrieb:
And then you see a photovoltaic system with the green roof around it. But who checks under the photovoltaic panels? Like with my neighbor: representatives from the local council or building authority.
But in the end, it doesn’t really matter. I WANT to have both. It’s not like I’m trying to avoid maintaining the green roof. So I have no problem greening the areas beneath the photovoltaic panels. Whether anything will grow in the shade remains to be seen... 😀
rick2018 schrieb:
Then please check with the building authority / planning office. That way, you get a legal statement.
Cooling effect through greenery for the units above lol
They will also be raised...
Of course, you can green the roof and then install the photovoltaic system on top. You just have to remove the substrate for the supports. But it makes more sense to leave it out.
I would definitely submit it with the building application. Why should the substrate for the supports be removed? And then install the photovoltaic mounting system directly on the drainage layer?
We have a green roof and a 9.9 kWp system on the roof. And I would always do it that way. Every flat roof specialist recommends greening because it provides additional protection for the roofing membranes.
@quisel: We installed the green roofs on our three flat roofs ourselves — main roof, “secondary roof,” and garage — it’s not rocket science.
Here is the construction on the main roof, 110 sqm (1184 sqft): root-resistant fleece 300 grams, 20 mm (0.8 inch) drainage layer with laminated fleece, then 8 cm (3 inches) of roof soil plus a 30 cm (12 inch) gravel edge.
On the “secondary roof” and garage, together 90 sqm (969 sqft): root-resistant fleece 300 grams, 9 mm (0.35 inch) drainage layer with laminated fleece, then 8 cm (3 inches) of roof soil plus a 30 cm (12 inch) gravel edge.
On the secondary roof, there is a 30 sqm (323 sqft) roof terrace, and the rest plus the garage are fully planted with sedum plants. On the main roof, only the area outside the photovoltaic system is greened.
Material costs were just under 4,000 EUR.
