ᐅ Granite tiles on a concrete floor?
Created on: 23 Oct 2017 18:49
Steven
Steven
23 Oct 2017 18:49
Hello
I want to cover my climate-controlled cellar (about 20m² (215 sq ft)) with granite tiles (30.5 x 30.5 x 1cm (12 x 12 x 0.4 inches)).
The slab = concrete floor is relatively level. Maximum unevenness is 5mm (0.2 inches).
Can I glue the tiles directly onto the concrete using flexible adhesive, or do I definitely need to use a leveling compound? I want to avoid the cost of leveling compound if it’s not absolutely necessary.
What do the experts say?
Steven
RobsonMKK23 Oct 2017 18:56
Steven schrieb:
The slab foundation = concrete floor is relatively level. Maximum unevenness of 5mm (0.2 inches).
Well, I’m no expert, but I would call that a “bumpy ride” 😉
Knallkörper
24 Oct 2017 07:28
It’s manageable. Our staircase situation was similar. Flexible adhesives can be applied up to 30mm (1.2 inches) depending on the type. That should be sufficient.
bluminger24 Oct 2017 09:24
What about rising damp through the concrete slab (capillary action)?
Steven
24 Oct 2017 10:09
Hello bluminger
Under the slab, I installed a full-surface dimple membrane. The slab is 30 cm (12 inches) thick waterproof concrete. There should be little to no moisture rising.
Steven
RobsonMKK24 Oct 2017 10:37
But honestly: you want to install extremely expensive tiles, yet you're hesitant about applying leveling compound. Why?
