ᐅ Giving KALLAX a Second Chance After Decades – How to Refresh It?
Created on: 31 Dec 2024 14:03
Posu59Hello everyone,
I am currently considering whether I can give my old IKEA KALLAX shelving unit from the early 1990s a second chance. Over the past decades, it has gathered a lot of dust, some of the cube inserts are worn out, and the design has become somewhat dull. My question is: How can I creatively and effectively refresh a KALLAX shelving unit that is now more than 20 years old to make it modern, functional, and visually appealing again?
I am thinking about new surfaces, colors, or maybe technical upgrades like LED lighting. It is important to me that this is not an expensive full renovation but a practical, sustainable way to reintegrate the furniture piece into a contemporary living style.
Perhaps some of you have tips or experience on how to give a KALLAX shelving unit a second life after decades? I am open to any ideas, whether DIY advice, painting, mixing materials, or practical enhancements. Thanks in advance!
Posu59 schrieb:
How can I creatively and usefully update a KALLAX shelf, which is now over 20 years old, to make it modern, functional, and visually appealing again?Hello Posu59,
First of all, I think it’s great that you want to give an older piece of furniture a new chance! There are several simple ways to visually enhance a KALLAX unit.
- Painting: Using a suitable primer followed by acrylic paint, you can transform the shelving into completely different colors. Matte or high-gloss finishes create a modern look.
- Use of decorative films: Self-adhesive films with wood patterns or trendy designs can quickly change the appearance.
- New baskets or boxes: IKEA now offers many different baskets and boxes that can also be combined well in terms of color.
- Lighting: LED strips along the shelves can add a stylish highlight – these are usually very affordable and easy to install.
You might also want to try combinations of these options. It is important to pay attention to material compatibility, especially when painting.
If you have any questions about any of these points, I’m happy to help!
Posu59 schrieb:
It has gathered a lot of dust over the past decades, some cube inserts are worn, and the design has become somewhat dull by now.Very good starting point for an ambitious project.
If you really want to comprehensively upgrade the KALLAX shelving unit, I recommend starting with a thorough assessment. This means checking each component (carcass, back panel, shelves, inserts) for stability and condition. Often it turns out that the load-bearing parts are still in very good shape, while the outer layer is worn out.
Step 1: Preparation
Remove all inserts and base fittings, sand the surfaces (grit 120–180, a bit coarser if old paint residues are present), and repair minor damages with wood filler.
Step 2: Priming and Painting
Use high-quality primers that ideally also protect against moisture—this will extend durability. Then apply paint in your preferred color. For a modern look, matte or satin finishes are currently very popular.
Step 3: Additional Design Elements
For new cube inserts, you can use materials like bamboo, metal mesh, or fabrics, which can also be interchangeable. One way to visually update the shelving unit is to design individual compartments with color or wallpaper.
Step 4: Lighting
Since you mentioned LED lighting: LED strips can be installed in continuous grooves around the edges. Make sure to conceal the power supply well and secure cables neatly. Battery-operated systems are an option if you want to avoid extensive wiring.
Technical Notes
Due to the material characteristics of the KALLAX (particleboard with melamine foil), surface preparation is crucial for good paint adhesion. It is recommended to use adhesion primers specifically designed for smooth surfaces.
If you like, I can also provide a materials list and recommend tools. What equipment or tools do you currently have available?
Important: Ensure good ventilation during all work steps and consider wearing protective masks if necessary.
flo-Theres31 Dec 2024 16:17Posu59 schrieb:
Maybe some of you have tips or experience on how to give KALLAX a second life after decades?Here is a well-proven tip: if you want a long-lasting refresh, replacing the back panel is worthwhile. The original back panel of the KALLAX is often just thin cardboard and provides little stability.
By using a self-cut MDF or plywood board, you can make the shelf significantly more robust while also adding a new surface that can be oiled, painted, or covered with a foil. This reduces wobbling and minimizes aging.
With some basic DIY skills, you can easily attach the back panel using small nails or screws. The everyday stability is very different compared to just the thin IKEA back panel. This way, you get a functional improvement and a great base for refurbishing.
Welcome to the new year!
Regarding "How to spruce up?", I would like to share a brief tutorial that I found very practical:
1. Surface reconditioning: Lightly sand the surface with fine sandpaper to dull any old glossy layers.
2. Primer: Use a primer suitable for melamine surfaces (e.g., synthetic resin-based bonding primer).
3. Paint: Apply an acrylic-based paint in the color of your choice—using a combination of roller and brush works best for a smooth finish.
4. Additional components:
a) Equip shelving compartments with fabric inserts made from durable textiles—sturdy boxes or custom-sewn covers work well for this.
b) LEDs: The most common are slim 12 V LED strips that can be easily cut to size, paired with a small power adapter that can be well concealed.
Common mistakes I noticed include insufficient surface preparation, applying paint layers that are too thick, and uneven finishes. Therefore, patience is essential.
If anyone is interested, I can gladly provide more details on tool usage or paint types.
Jensson schrieb:
LED strips with 12 V that are easy to cut. Most LED strips operate at 12 V, but make sure to use power supplies with adequate current capacity.
Jensson schrieb:
Fit shelves with fabric inserts made from durable textiles Old pillowcases or curtain fabric work well for this—quick and inexpensive.
That’s all you need.
