April201314 Nov 2012 15:02Hello dear forum community,
We received the quote for our tunnel fireplace today. Could you please tell me if it looks good or if there’s anything else I should consider?
Glass heating door W67 x H56cm (W26 x H22 inches) with external fresh air ventilation, self-closing, infrared-coated
1299,- net
Firebox insert including 1 self-closing glass heating door W67 x H56cm (W26 x H22 inches), infrared-coated glass, fresh air supply with 1 heat exchanger (water output depending on wood consumption 14 - 22 kW)
4260,- net
Heating output: 80% water, 20% into the room
Of course, we still have a consultation appointment, but what do you think — what other costs might be involved? Installation? Inspection? What additional expenses should we expect?
Thank you very much
1299,- net
4260,- net
Thank you very much
karliseppel14 Nov 2012 15:25Somehow, this unit still needs to be installed – I’m thinking it will be built using fireclay bricks.
There will be more to come… at the moment, this is just a list of materials…
In my experience with other finishing trades, the formula material costs = installation costs has often proven accurate…
You shouldn’t overlook the connection to the heating system and any additional work required on the heating technician’s side due to system specifics. The thermal safety valve also adds some cost. Altogether, I’m expecting a price (just for the stove installer) just under 10,000 euros.
You guys have also picked a Mercedes model, after all.
By the way, I find the door’s aspect ratio unfavorable. It looks too square. Nowadays, people are mostly used to 16:9.
I also think that the 20% heat output into the room is somewhat optimistic.
April201314 Nov 2012 15:58I will bring up the size again, I would prefer it to be more elongated, as you already mentioned...
Can you recommend manufacturers that aren’t so premium-focused?
This was the first quote; we still have some time, but you have to start somewhere... Of course, we will get additional quotes...
But basically, everything that is needed is included, right????
karliseppel14 Nov 2012 18:28Are you installing a cooker hood and/or an extractor fan?
In that case, a reed switch or a USA sensor will also be required at the window.
karliseppel14 Nov 2012 19:05karliseppel schrieb:
Are you getting a mechanical ventilation system and/or a range hood?
Then a reed switch or a USA sensor will be needed at the window. Sorry for the bad word recognition on my phone lol.
April201314 Nov 2012 20:54We will have a decentralized ventilation system and an exhaust hood in the kitchen... Or are you referring to something else????
