ᐅ Cleaning Ikea Metod glass fronts gently without streaks or scratches
Created on: 14 Feb 2023 08:12
Luanon
Luanon
14 Feb 2023 08:12
Hello everyone, I recently received my Ikea Metod kitchen with glass fronts and am now facing the challenge of cleaning them gently. I definitely want to avoid streaks, as they are especially noticeable on glass fronts, and above all prevent scratches completely, since the surface seems delicate. My previous cleaning attempts with regular all-purpose cloths unfortunately resulted in slight streaks and even small scratches, which is obviously not ideal.
I am interested in the most effective method to clean the Metod glass fronts. Are there specific cloths, cleaning products, or techniques you would recommend to clean the glass without leaving streaks or risking scratches? What tips can you share from your experience when it comes to caring for Ikea Metod glass fronts? Many thanks in advance for your help!
O
olivernu
14 Feb 2023 09:53
The best method to clean glass fronts like those in the Ikea Metod system is actually a combination of a microfiber cloth and clean water.
- Use a high-quality microfiber cloth, as these do not cause scratches and clean effectively.
- Slightly dampen the cloth with lukewarm water, avoiding using too much water to prevent streaks.
- Avoid harsh or abrasive cleaning agents, as they can damage the surface.
If there is heavier dirt, you can add a small amount of mild dish detergent to the water, but make sure to wipe the glass afterwards with a damp cloth without any detergent. This procedure reduces streaks and protects the surface.
Joe52
14 Feb 2023 11:04
I can fully understand how frustrating it is when glass panes remain streaky despite careful cleaning or when you even worry about scratching them.
What has helped me is a two-step approach: first, remove all coarse dirt with a damp microfiber cloth, then use a special glass cleaning cloth (these are often cloths with a very fine texture) dry for polishing.
Sometimes, simply dry wiping makes more of a difference than just wiping with a damp cloth. It is also important to change or wash the cloth regularly to avoid spreading dirt particles and prevent scratches.
draleo
15 Feb 2023 07:39
To avoid streaks and scratches on Ikea Metod glass fronts, I recommend the following:
- Use only non-abrasive microfiber cloths or lint-free cotton cloths.
- Avoid paper towels or coarse sponges, as these can cause micro-scratches.
- Cleaning agents should be pH-neutral and alcohol-free, since harsh chemicals can damage the surface sealant.
Research and product instructions show that glass fronts in kitchen cabinets often have a protective sealant. This can be harmed by overly aggressive cleaners or physical stress. A light spray of a 1:10 dilution of dish soap and water is usually sufficient to remove dirt. Afterwards, wipe with a clean cloth and gently dry-polish the surface.
It is advisable to dry with a clean leather cloth or microfiber cloth without any additives. It is also important to clean promptly so that water spots do not dry and cause streaks.
Bagupo
15 Feb 2023 12:27
I always use only clear water and a soft microfiber cloth. No cleaning agents, no alcohol. This way, no scratches occur and hardly any streaks are visible.
O
olivernu
16 Feb 2023 06:58
Joe52 schrieb:
Sometimes simply wiping dry makes more of a difference than just wiping damp.
Exactly, drying is an essential step to avoid streaks. Often, the differences become visible only when the surface is dry. It is important that the cloth is clean and as lint-free as possible.
Additionally, during longer cleaning sessions, the cloth should be rinsed regularly to prevent dragging dirt particles across the surface, which can cause scratches.
