ᐅ Gas valve and handbrake of the heating system: Is this explanation correct?
Created on: 22 Nov 2020 15:05
V
vaderle
I have been living in my new house for four months.
Our house (16cm (6 inches) aerated concrete precast walls + insulation) has underfloor heating on both the ground and first floors, as well as a heating system (air-to-water heat pump) from Vaillant.
In every room, I have individual temperature controllers, and at the location of the heating system (utility room), there is a separate control panel from Vaillant where I can set the general desired temperature as well as time-limited temperature adjustments (for example, lowering the desired temperature by 4°C (7°F) at night).
At first, I set the temperature in many rooms to around 21°C (70°F), 19°C (66°F) in the bedroom, and 22°C (72°F) in the bathroom. The central control panel was set to a desired temperature of 23°C (73°F).
Since it was almost always warmer in the rooms than the temperature set on the controllers due to good insulation and outside temperatures, heating was almost never activated. Only in the utility room did it seem like continuous heating took place during the day. As a result, the temperature there was around 24-25°C (75-77°F). This was clearly too warm for me because food is also stored there. Both the separate room controller (set to 18°C (64°F)) and the central control panel (with the central desired temperature of 23°C (73°F)) in the utility room were set lower. I therefore spoke with the heating engineer.
He explained the following:
The central control panel is like the gas pedal of a car, and the individual room controllers are like handbrakes.
So I was always “driving with the handbrake on” (individual room controller set lower than the central control panel in the utility room). This caused the warm water in the underfloor heating system to accumulate in the utility room.
He advised me to set all the room controllers to a higher temperature (for example, 25°C (77°F))—in other words, release the handbrake—and then slowly lower the central desired temperature setting (the gas) until the desired effect is achieved. This way, the air-to-water heat pump would run continuously because the actual temperatures in the rooms would never match the set values, and the utility room would no longer experience this accumulated heat. He also said that in a house with insulation and an air-to-water heat pump, it is good for the system to run continuously.
Is this explanation using the gas pedal and handbrake analogy correct?
lesmue79
27 Nov 2020 19:50
Is a bypass valve installed and possibly incorrectly adjusted? Could it be that a large portion of the flow volume is passing unused through the valve’s bypass from the supply line to the return line?
Daniel-Sp
27 Nov 2020 20:55
From what I have read from @Bookstar, I conclude that the overflow valve is closed.
Bookstar
27 Nov 2020 21:15
Yep, the main water valve is completely shut off.
Bookstar
27 Nov 2020 21:16
Daniel-Sp schrieb:
Didn't you have a modulating heat pump? It also reduces the flow rate when maximum output is not required. The flow is modulated down to achieve the optimal temperature difference in the heating circuit for the best operating point at the corresponding outdoor temperature. In theory, you can switch the control of the heat pump in the Luxtronic from automatic to manual 100%. Then you can see what your hydraulics are capable of. But for "daily use" that doesn't make sense, as it causes a loss of efficiency.
Do you know the password for the settings?
Yes, I did try that once, I remember. Then the pump was clearly audible and the sight glasses showed a much higher flow. But I think the auto setting must have its purpose.
Daniel-Sp
27 Nov 2020 21:22
So everything is fine. Consumption is correct, temperature is correct. What do the sight glasses matter? The heat pump regulates everything for optimal operation.
V
vaderle
29 Nov 2020 22:00
Thanks again for the tips. I have now lowered the temperature from 24°C (75°F) to a comfortable 21.5°C (71°F) with a heating curve of 0.2.
