ᐅ Gas valve and handbrake of the heating system: Is this explanation correct?
Created on: 22 Nov 2020 15:05
V
vaderle
I have been living in my new house for four months.
Our house (16cm (6 inches) aerated concrete precast walls + insulation) has underfloor heating on both the ground and first floors, as well as a heating system (air-to-water heat pump) from Vaillant.
In every room, I have individual temperature controllers, and at the location of the heating system (utility room), there is a separate control panel from Vaillant where I can set the general desired temperature as well as time-limited temperature adjustments (for example, lowering the desired temperature by 4°C (7°F) at night).
At first, I set the temperature in many rooms to around 21°C (70°F), 19°C (66°F) in the bedroom, and 22°C (72°F) in the bathroom. The central control panel was set to a desired temperature of 23°C (73°F).
Since it was almost always warmer in the rooms than the temperature set on the controllers due to good insulation and outside temperatures, heating was almost never activated. Only in the utility room did it seem like continuous heating took place during the day. As a result, the temperature there was around 24-25°C (75-77°F). This was clearly too warm for me because food is also stored there. Both the separate room controller (set to 18°C (64°F)) and the central control panel (with the central desired temperature of 23°C (73°F)) in the utility room were set lower. I therefore spoke with the heating engineer.
He explained the following:
The central control panel is like the gas pedal of a car, and the individual room controllers are like handbrakes.
So I was always “driving with the handbrake on” (individual room controller set lower than the central control panel in the utility room). This caused the warm water in the underfloor heating system to accumulate in the utility room.
He advised me to set all the room controllers to a higher temperature (for example, 25°C (77°F))—in other words, release the handbrake—and then slowly lower the central desired temperature setting (the gas) until the desired effect is achieved. This way, the air-to-water heat pump would run continuously because the actual temperatures in the rooms would never match the set values, and the utility room would no longer experience this accumulated heat. He also said that in a house with insulation and an air-to-water heat pump, it is good for the system to run continuously.
Is this explanation using the gas pedal and handbrake analogy correct?
Joedreck
27 Nov 2020 08:50
The question is whether it has always been like this...
Mycraft27 Nov 2020 10:06
Then the pump is simply too weak for the size of your system, if you need a higher flow rate.
T_im_Norden
27 Nov 2020 16:47
@vaderle
You don’t need to use formal language; usually, people use informal address in forums.
You can lower the maximum temperature, but the heating system should never exceed 50°C (122°F) if it is properly designed.
You probably received documents from the heating installer, such as pipe circuit lengths, heat load calculations, and the design flow temperature for the underfloor heating system.
V
vaderle
27 Nov 2020 19:32
I will take a look at the documents. A question just came up spontaneously. During the day, I checked the flow temperature from time to time. Is it normal for it to vary? Sometimes it was 24°C (75°F), other times 28°C (82°F) or 30°C (86°F). Or should it actually stay at a constant value?
By the way, I have now set the heating curve to 0.2. It feels like the temperature has dropped a bit, although we still reach a comfortable 23°C (73°F).
T_im_Norden
27 Nov 2020 19:37
Yes, the flow temperature varies partly depending on the outside temperature (heating curve) and whether heating is currently active. Most systems do heat somewhat beyond the set flow temperature and only restart once the temperature drops by a certain value to avoid constant switching on and off. These values are usually in the range of 4 to 7 degrees Celsius (39°F to 45°F).
It can take 24 hours or more before you notice changes in underfloor heating.
Daniel-Sp
27 Nov 2020 19:44
Bookstar schrieb:
Does anyone know why I only get a maximum flow of 1 liter (1 quart) in the sight glasses? They are fully opened.
Didn’t you have a modulating heat pump? It also reduces the flow when maximum output is not required. The flow is modulated down to achieve the optimal temperature difference in the heating circuit for the best operating point according to the outside temperature. In theory, you can switch the control of the heat pump in the Luxtronic system from automatic to manual at 100%. Then you can see what your hydraulics can do. But for daily use, this doesn’t make sense because it causes a loss in efficiency.
Is the password for the settings known?
