ᐅ Gas valve and handbrake of the heating system: Is this explanation correct?
Created on: 22 Nov 2020 15:05
V
vaderle
I have been living in my new house for four months.
Our house (16cm (6 inches) aerated concrete precast walls + insulation) has underfloor heating on both the ground and first floors, as well as a heating system (air-to-water heat pump) from Vaillant.
In every room, I have individual temperature controllers, and at the location of the heating system (utility room), there is a separate control panel from Vaillant where I can set the general desired temperature as well as time-limited temperature adjustments (for example, lowering the desired temperature by 4°C (7°F) at night).
At first, I set the temperature in many rooms to around 21°C (70°F), 19°C (66°F) in the bedroom, and 22°C (72°F) in the bathroom. The central control panel was set to a desired temperature of 23°C (73°F).
Since it was almost always warmer in the rooms than the temperature set on the controllers due to good insulation and outside temperatures, heating was almost never activated. Only in the utility room did it seem like continuous heating took place during the day. As a result, the temperature there was around 24-25°C (75-77°F). This was clearly too warm for me because food is also stored there. Both the separate room controller (set to 18°C (64°F)) and the central control panel (with the central desired temperature of 23°C (73°F)) in the utility room were set lower. I therefore spoke with the heating engineer.
He explained the following:
The central control panel is like the gas pedal of a car, and the individual room controllers are like handbrakes.
So I was always “driving with the handbrake on” (individual room controller set lower than the central control panel in the utility room). This caused the warm water in the underfloor heating system to accumulate in the utility room.
He advised me to set all the room controllers to a higher temperature (for example, 25°C (77°F))—in other words, release the handbrake—and then slowly lower the central desired temperature setting (the gas) until the desired effect is achieved. This way, the air-to-water heat pump would run continuously because the actual temperatures in the rooms would never match the set values, and the utility room would no longer experience this accumulated heat. He also said that in a house with insulation and an air-to-water heat pump, it is good for the system to run continuously.
Is this explanation using the gas pedal and handbrake analogy correct?
T_im_Norden
25 Nov 2020 12:14
This is related to the heating curve.
I’m not exactly sure how your manufacturer defines the desired temperature.
Please provide more detailed information about your system.
Then it will be easier to assist you.
V
vaderle
25 Nov 2020 16:20
So, we have:
Vaillant Arotherm VWL 55/5 with Unitower 58/5. The central control unit is called "SensoComfort."
T_im_Norden
25 Nov 2020 17:36
The Sensocomfort manual explains or mentions several terms, such as flow temperature and heating curve.
Please check the flow temperature at which the system is operating.
V
vaderle
26 Nov 2020 07:06
I have gathered some data:
Water pressure: 1.5 bar
Adaptive heating curve: disabled
Hybrid manager: bivalence point
Bivalence point heating: 0°C (32°F)
Bivalence point domestic hot water: -7°C (19°F)
Emergency operation temperature: 25°C (77°F)
Utility company control: heat pump off
Additional heating device: domestic hot water + heating
Current flow temperature: 38°C (100°F)
Outdoor temperature cutoff: 21°C (70°F)
Heating curve: 1.20
Minimum target flow temperature: 15°C (59°F)
Maximum target flow temperature: 90°C (194°F)
For domestic hot water:
Target flow temperature: 0°C (32°F)
Storage charging pump: off
Circulation pump: off
Legionella protection day: off
I am a complete beginner, but isn’t a heating curve of 1.20 for underfloor heating too high? And should the adaptive heating curve be turned off?
Joedreck
26 Nov 2020 07:15
Open all valves fully and set the heating curve to a relaxed 0.4. A setting of 1.2 is typical for radiators in a house built around 1990.
halmi
26 Nov 2020 07:30
A flow temperature of 38 degrees Celsius (100 degrees Fahrenheit) is really cozy.
