ᐅ Gas or heat pump in a KfW55 energy-efficient house
Created on: 17 May 2016 23:08
Becker84
Hello, I am currently trying to evaluate the advantages of gas versus electricity.
I’m assuming an annual demand of 5000 kWh including hot water.
What is a realistic seasonal performance factor (SPF) for 2 deep boreholes or for collectors just a few meters underground?
Heat pump costs around €310 for 1500 kWh => SPF 3.3
I have concerns about heat pumps regarding hot water production, as the efficiency is likely to be low when there is a temperature difference of 40-60°C (104-140°F). This is likely to reduce the overall seasonal performance factor, even though the SPF for underfloor heating at 25-30°C (77-86°F) can be above 4.5.
Is anyone’s practical experience available on this?
Gas costs are almost exactly the same at €310.
Purchase costs for gas:
- Gas boiler with solar and hot water 3000-5000 € ?
- Gas connection ? ?
Purchase costs for heat pump:
- Heat pump with hot water storage tank approximately 6000 € ?
- Deep borehole including installation 10,000 € ?
- Or ground collectors ? ?
+ BAFA subsidy 4500 €
Does it make sense to buy a separate air-source heat pump for hot water that is located inside the house and therefore has to heat from approximately 20°C (68°F) to 60°C (140°F)?
Or would it be better to purchase a heat pump with an integrated hot water tank and a solar connection, similar to a gas boiler?
If the operating costs (without photovoltaic system) are roughly the same, I would tend to choose the heat pump, since photovoltaic would allow additional savings in the future.
Goldi09111
19 May 2016 22:15
I'm really not sure if the additional investment in a heat pump compared to gas will ever pay off. Which parameters should you base the calculation on? No one knows what gas or electricity prices will be in the future...
Saruss
19 May 2016 22:31
The better a house is insulated, the less important the heating system becomes – you can save a higher percentage on very low heating costs, but in absolute terms the savings are minimal. Aside from that, gas is not available everywhere. For the environment, a heat pump (preferably geothermal) combined with solar power is probably the best option.
