ᐅ Gas heating, solar thermal systems, and wood-burning stove with water circulation: pros and cons
Created on: 23 Aug 2012 06:43
Josi80
Josi80
23 Aug 2012 06:43
Good morning everyone,
I am planning a major renovation of a residential building and want to combine a gas heating system with solar thermal for domestic hot water and a water-jacketed wood stove for additional heating support.
Does such a setup even make sense?
I already have the wood stove. Can you recommend affordable systems? I basically need the entire heating system: gas boiler, buffer tank, solar panels including all accessories (except the wood stove).
Thanks in advance for your tips!
€uro
23 Aug 2012 09:11
Josi80 schrieb:
...I am considering combining a gas heating system with solar thermal (domestic hot water) AND a hydronic wood stove (heating support) for an extensive residential renovation. Does this even make sense?
Only in exceptional cases. The more components involved in heat generation, the lower the overall efficiency tends to be (due to competing demands). This limits cost-effectiveness.
I would focus primarily on one heat source and optimize that system.
Reliable conclusions can only be drawn once the actual demand for heating and hot water is known.
Energiefuxx
28 Aug 2012 10:54
@ Engineering Office: MEP Planning and Energy Consulting
That's exactly the case. You either prioritize solar thermal energy—not just for domestic hot water but also for heating support—and choose a large storage tank combined with a radiant floor heating system, such as a capillary tube system (supply temperatures 24-28°C (75-82°F)). In most cases, a wood stove alone is sufficient to cover peak loads. All of this can be easily calculated.
Energiefuxx
