ᐅ Gas Boiler vs. District Heating
Created on: 25 Jan 2011 16:37
Hilaria
Hilaria
25 Jan 2011 16:37
Hello, we are about to make our first big decision.
Gas boiler or district heating?
Everything else is ruled out.
So my question is, what are the pros and cons of each option?
Personally, I lean towards district heating simply because you don’t have to worry about anything later on.
But I’m happy to get advice or be corrected.
Hilaria
Erik_I
27 Jan 2011 14:50
Hello Hilaria,
First of all, I would ask how the district heating is generated. Is it, for example, waste heat from industry, and what happens if the facility shuts down? Or is it a combined heat and power plant located nearby (which would technically be called local heating)? What energy source is used to generate the heat? What primary energy factor applies to the final energy (this is a general topic and of interest when demonstrating compliance with energy-saving regulations)?
District heating does not have as efficient a performance as, for example, gas condensing technology.
You write that an advantage is that with district heating you don’t have to worry about anything later. I think it is a disadvantage that you can’t take care of anything! There is no option to switch providers if prices increase or if the supplier ceases operation. In general, gas prices will no longer be linked to oil prices in the future. Also, competition among gas suppliers will grow, which should benefit customers.
An advantage of district heating is certainly that there are no costs for reinvestment in plant technology every 20 to 25 years. The often mentioned advantage that district heating—unlike gas heating—does not require a chimney is not entirely correct. Modern gas condensing systems do not require a chimney and, under certain conditions, only need a plastic pipe vented outside.
I hope I have provided you with a satisfactory answer.
