ᐅ Rotary tiller for topsoil, electric / petrol (gas) powered
Created on: 26 Mar 2015 11:48
HilfeHilfe
I had about 20-30 cm (8-12 inches) of topsoil dumped over the old lawn. I shaped it as best as I could with a rake. Right now it is settling, and after April I want to start reshaping and seeding.
I realized that working with a shovel and rake is backbreaking work. It’s about 80-100 square meters (860-1,080 square feet) that need to be dug up. What do you think—is it better to rent a decent gas-powered garden tiller or buy a small electric garden tiller (1050 W)?
Does anyone have experience?
You need to have a steady hand; otherwise, you'll end up with patchy grass =) For around 30 euros, I would get a spreader (from Gardena or a similar brand). It allows you to control the application rate well and ensures a neat job. You can also use the spreader later for fertilizing the lawn (I always use natural fertilizers from brands like Neudorff) or for spreading grit in winter, etc. A lawn roller would also be useful; mine cost about 45 euros online. But you can probably rent one somewhere as well.
I personally borrowed a lawn seeder from a landscaping contractor, which was absolutely fantastic *g*
Bauexperte30 Mar 2015 10:21Hello,
Regards, Bauexperte
HilfeHilfe schrieb:I wasn’t thinking about an English lawn specifically when I replied; I really like having life on the lawn. However, there are certain plants I don’t want in the lawn because I can’t control them unless I catch them in the early stages, and I rarely have the time for that. That’s also why the old lawn has to go; unfortunately, it’s not even good enough to be considered a meadow… regardless of what my neighbors think about it
With all the grooves and so on, it’s getting too complicated for me. I’ll start by milling around, modeling the whole thing, sowing it, and then we’ll see. I’m not fooling myself—there will always be some rework if you want to have an English lawn by 2025
HilfeHilfe schrieb:I did it by hand; but you need a consistent rhythm, otherwise it won’t work well. The Gardena ® spreader can help and is not too expensive.
Another silly question, I don’t want to buy all the equipment—should I spread the grass seed by hand, or is there a better way??
Regards, Bauexperte
Instead of doing the waltzes, you can also strap boards to your feet and walk across the floor before and after.
A neighbor did that. However, their lawn is only about 30 sqm (320 sq ft).
