I am currently looking for a 200cm (79 inches) long outdoor garden table.
The table should be weather-resistant since it will be kept outside all year round. It also needs to be rainproof because, honestly, I don’t want to cover it every time it rains.
Additionally, the maintenance should be very low (so wood might not be suitable?).
Which material for the tabletop would be most suitable in this case?
Do you have any experience you can share?
The materials should be available within a budget of up to 500€.
Bertram1009 Jul 2024 11:20I would recommend wood. It’s not that high-maintenance. Just oil it well once in the fall. Cleaning the brush afterward takes about 30 minutes. Well-oiled tables are very durable.
Besides, I think wood matches everything and creates a cozy atmosphere. My neighbors have a glass table. I find it terribly cold and definitely wouldn’t want such a bulky piece in my own garden.
Bertram100 schrieb:
I would recommend wood. It’s not that high-maintenance. Just oil it well once in the autumn. Cleaning the brush afterwards takes about 30 minutes. Well-oiled tables are very durable.
Besides, I think wood matches everything and creates a cozy atmosphere. My neighbors have a glass table—I find that terribly cold, and I definitely wouldn’t want such a bulky piece in my own garden. With ceramic, plastic, or polywood, as well as HPL, you get the option of a “wood look.” I’m really a fan of that... We even have wood-look tiles indoors, which in my opinion combine a cozy feel with durability.
However, since I’ve only ever had a glass table before and don’t want one anymore, I’m quite inexperienced with outdoor tables...
I’ve read a lot about teak wood—is it really enough to oil it just once and then leave it uncovered outside in all kinds of weather?
Prager91 schrieb:
The materials should be available within a budget of up to 500€ (about $540). Prager91 schrieb:
The question is, what exactly can you get for that? Prager91 schrieb:
There is a lot of discussion about teak wood. In my opinion, you won’t find anything within 500€ (about $540) that meets your requirements. Except for the typical hardware store products, which may not be very UV resistant or whose surface quality might not live up to the claims.
During the damp season, I would cover everything because dust, bird droppings, and rain all leave marks. Even light rain can settle a few days’ worth of dust on the surface, making it visible.
For example, we have a surface like Polywood or something similar. Our table has been used for several years; it works but isn’t exactly attractive. In the first few years, it stood outside with a cover over winter, but now it’s under a roof.
I personally see teak as an alternative, but it is quite expensive. There are many “imitations.” Also, I’m not sure if it’s the right surface for you, especially if you mean stained teak, because it is quite open-pored.
In my opinion, you won’t get anything for €500 that meets your requirements.
Except for the DIY store products mentioned, which may not be UV-resistant for long or whose surface might not be as promised.
During the damp season, I would cover everything, as dust, bird droppings, and rain leave their marks.
Even light rain makes dust from just a few days visible on the surface.
For example, we have this surface, whether it’s polywood or something similar. The table, which is already several years old, still works but doesn’t look great. For the first few years, it was outside with a cover in winter; now it has a roof over it.
I personally consider teak as an alternative, but it’s very expensive. There are many “fakes” out there. Also, I’m not sure if it’s the right surface for you, since teak tends to be quite porous, especially if you mean lacquered teak. I understand that a €300 product from a DIY store, like polywood, won’t guarantee durability regarding UV resistance for the next 10 years – I am fully aware of that.
In the near future, within 3-4 years, a roof or shelter is planned, so I might be open to wood at that point.
Right now, the goal is to find the most affordable table possible that requires little maintenance and still looks decent for the next few years. It should be fairly resistant and stable.
I ordered a product from a large supermarket chain. It looked nice but was much too light and unstable. Many affordable products from DIY stores weigh only about 25 kg (55 lbs) – that’s definitely too little.
I imagine a sturdy aluminum frame with a durable, low-maintenance tabletop.
I will of course cover the furniture during heavy rain or for several days afterward — no question about that.
But honestly, I don’t want to cover my furniture every time the weather changes slightly.
Bird droppings, dirt, rain, etc… I’m thinking more like: I sit outside and just quickly wipe down the table — that’s why it needs to be low-maintenance!
I absolutely hate garden furniture covers… They often take away the enjoyment of sitting outside, because you have to cover everything nicely again afterward.
So, I need a reasonable temporary solution for the next 3-4 years.
Bertram1009 Jul 2024 12:46I would get a second-hand wooden table for 50 euros and use it for now until the roof structure is in place and you’ve made your final decision.
Even if there are really durable materials available, they usually contain plastic and give off a plastic-like appearance, including wood alternatives.
In your situation (I don’t like cleaning either), I wouldn’t look for the perfect all-in-one solution right away, especially if there might still be major changes on the terrace.
Wood weathers with a certain style, while plastic unfortunately does not. That’s another point in favor of second-hand wood.
Prager91 schrieb:
So I need a practical temporary solution for the next 3-4 years. In that case, the wood-look options are actually a good choice. I don’t consider 25 kg (55 lbs) to be light – ours (100 x 200 cm (39 x 79 inches)) with an aluminum frame is probably lighter but still stable. We also see it as an advantage that it can be quickly turned or moved alone when sweeping.
You might want to visit a hardware, furniture, or garden center to see and judge the stability for yourself.
Bertram100 schrieb:
Wood weathers with a bit more character, plastic unfortunately does not. Another point in favor of secondhand wood. If you consider all the questions and background the original poster raised, or remember their preferences, wood is definitely the wrong choice.
@Prager91 please don’t take this negatively.
