ᐅ Anthracite Garage Facing South – Is a Dark Color Problematic?
Created on: 20 Aug 2018 09:56
Grantlhaua
We had to orient our garage to the south and have now learned that dark colors might cause issues here.
Have you had any experience with this?
Grantlhaua
22 Aug 2018 09:59
mertmk3 schrieb:
Sections not too large
Does that mean not using L-shaped stiffeners, or are you referring to the width?
The stiffening profiles were included by default in our offer. However, I’m not sure if they are sufficient.
mertmk3
22 Aug 2018 13:45
Yes, I would avoid sections that are exactly 52cm (20.5 inches) wide. It is better to use narrower ones, each with its own stiffening profile for reinforcement.
hanse987
22 Aug 2018 14:56
May I ask a simple question? What exactly is meant by a stiffening profile? Where is it installed?
mertmk3
22 Aug 2018 15:03
On the inside of the gate, a capping profile is screwed across as much of the section width as possible.
Aliban2014
22 Aug 2018 16:06
mertmk3 schrieb:
On the inner side of the door, a hat profile is screwed across as much of the section width as possible.
Thanks for the information, then we should probably insist on the hat profiles, although there’s one thing I don’t understand, since I’ve never seen it or have experience:
Does the slat bend inward and outward, or only outward?
So far, I always understood that the outer sheet metal bends, so what’s the purpose of hat profiles on the inside?
Slat construction (cross-section):
Outside steel, foam core, inside steel
Then the hat profile is only attached on the inside, right? Or are you referring to a single-wall sectional door?
I saw a so-called “Silkgrain” surface in the Hörmann catalog, which uses thicker steel sheet than the standard one.
Does anyone have experience with this on a south-facing garage, especially regarding bending? Is it worth it?
11ant22 Aug 2018 17:18
Aliban2014 schrieb:
So far, I’ve always understood that the outer metal sheet bulges, so what’s the point of hat profiles on the inside?
There has to be a secure mechanical connection between the outer and inner profile half-shells; otherwise, the outer shell would practically lift off the flange if the inner shell doesn’t follow. The hat profile is only useful if it can indirectly transfer forces to the outer shell.
Perhaps a new generation of panels with insulation layers featuring a cryogel function will be available soon (or the night-gray roller shutter trend will pass).
