Good morning dear forum,
I have a question regarding our house planning:
Every year, the regulations for houses and their insulation (new builds & existing buildings) are becoming stricter. If I build now – assuming a 36cm (14 inch) masonry wall with a thermal conductivity of 0.09 – will I have to retrofit/add insulation in the future?
If that is the case, are there wall specifications (thickness/thermal conductivity) that exclude the need for later insulation?
Thank you and best regards,
Peter
Peter
Best regards.
PeterXYZ schrieb:This usually applies to new constructions.
...Every year, the regulations for houses and their insulation (new build & existing buildings) become more stringent.
PeterXYZ schrieb:That’s no longer solid (monolithic) masonry, but more like a crumbly monster ;-)
...If I build now – assuming 36 cm (14 inches) masonry with a thermal conductivity of 0.09 – will I have to retrofit or add insulation in the future?
Best regards.
That’s no longer a solid block (monolithic), but more like a crumbly monster ;-) My first guess would be aerated concrete (Ytong) ^^
If I build now – assuming 36cm (14 inches) masonry with a thermal conductivity of 0.09 – will I need to do additional insulation later?Maybe if the facade needs renovation in 20 years… otherwise, it probably won’t come to that…
If that’s the case, are there wall specifications (thickness/thermal conductivity) where additional insulation can be ruled out?About 80–90cm (31–35 inches) of aerated concrete and up should be enough to be on the safe side for now!
Hi,
I interpret the first two replies as suggesting that any improvements would only be necessary, at the earliest, during a facade renovation.
Otherwise, the two responders seem to be opponents of monolithic construction ("cookie monster," "80-90cm Ytong blocks"), right?
PeterXYZ schrieb:
Otherwise, the two responders seem to be opponents of the monolithic construction method ("cookie monster", "80-90cm Ytong")? No, you need to differentiate here. Is it self-construction or professional work? In the latter case, it always makes sense to separate structural load-bearing (static), sound insulation, and thermal insulation, meaning each aspect should be handled by the respective specialist. Anything else would be a compromise. In self-construction, the situation often looks somewhat different, as other factors also come into play.Best regards
