nordanney10 Mar 2024 13:26Jimy3435 schrieb:
How does the heat exchange work then? Inside the unit, there is only a metal block in the middle. It surely can’t be simultaneously flowed around from two directions, can it? This is a cross-flow / counterflow heat exchanger. And yes, the heat exchange happens through the metal block. Look up the principle online to understand it better. Unfortunately, links are not allowed here.
"The special feature of this unit is its counterflow technology. The supply and exhaust air are directed past each other in separate channels, where the warm exhaust air warms the cold supply air. This not only saves energy but also allows for a consistent, continuous air supply."
==> Have you already checked the device’s description?
