ᐅ Front door with Ekey (fingerprint access) but without panic function
Created on: 16 Jul 2015 16:31
b2see
I am currently looking for a suitable front door.
Here is the issue: My front door should have an Ekey, but I do not want the door to be easily opened from the inside by simply pushing down the handle if it was locked from the outside using the Ekey. This is supposedly called a panic function, which I definitely do NOT want.
Now the question is whether there are front doors or locks that do not have this "panic function"?
Regards, b2see
Koempy17 Jul 2015 09:56
Burglars always look for the weak spots in a house. Usually, the front door isn’t one of them. It’s more often windows that are left tilted open or patio doors. These are much easier to break into discreetly. I wouldn’t worry much about the front door and would focus more on the rest of the house.
Musketier17 Jul 2015 10:06
Lexmaul79 schrieb:
And how are you supposed to get out unlocked with a fixed knob?
My idea would be an additional fingerprint scanner on the inside or a button located a short distance away from the door/window. Then a knob would work as well.
I think this is simply a safety feature, for example in case of a fire. You shouldn’t have to search for a key first.
Boergi
17 Jul 2015 10:25
Lexmaul79 schrieb:
And how are you supposed to go outside unlocked with a fixed knob?
Good point, I knew I had forgotten something.
As already mentioned, you would need to install a button near the front door to open it. However, none of these solutions seems very practical.
Sebastian79
17 Jul 2015 21:06
And what if there is a fire and the power goes out? If you are already planning the construction, then do it properly – although this wouldn’t be entirely unrealistic.
