ᐅ Flush-mounted electrical boxes not recessed into exterior wall surface
Created on: 6 Jun 2025 07:17
knabbels
knabbels
6 Jun 2025 07:17
Exterior wall of a building with downpipe and two red wall holes.
We had the electrician install power for outdoor cameras. The flush-mounted boxes now stick out several centimeters (inches) beyond the plaster. Is this normal? How should an outdoor camera or a cover be mounted on this without it looking really awkward? What do you think?
familie_s6 Jun 2025 08:19
Is that really the electrical box, or just the plaster adjustment ring? If it’s the latter, you can replace it with a narrower one.
knabbels
6 Jun 2025 09:13
I was not aware of that; I will check it.
familie_s6 Jun 2025 09:27
Kaiser flush-mounted boxes are black or gray, and the spacer rings are red. So it is very likely.
11ant6 Jun 2025 14:40
knabbels schrieb:
We had the electrician install power for outdoor cameras. The flush-mounted boxes now protrude several centimeters (inches) beyond the plaster. Is this normal? How are you supposed to attach an outdoor camera or a cover without it looking really awkward? What do you think?
For splash protection reasons, I find it hard to imagine that flush-mounted boxes are the right choice for an outdoor installation.
hanse987
6 Jun 2025 17:50
knabbels schrieb:
The flush-mounted boxes now protrude several centimeters above the plaster. Is that normal?
No, that’s not normal, but what exactly did you order? This doesn’t look like it was planned properly.
Why power only and not network cables?
