ᐅ Floor plan of a single-family house with a double garage and a terrace
Created on: 31 Oct 2013 10:04
Schwupp
I’m new to the forum and would like to share the first floor plan of my planned single-family house.
I’ve just received the initial draft from my architect. It turned out that the house is somewhat undersized.
The architect will now increase the exterior dimensions by about 2 meters (6.5 feet) in length so that the rooms are not too small.
My question to you:
What do you think of the room layout?
Does the terrace above the garage seem too large, or is it acceptable as it is?
I’m looking forward to your feedback.
Andre
Hello Andre,
Since you’ve posted your drafts here for discussion, I took the liberty of uploading them in a way that makes it easy for users to share their ideas or suggestions for improvement. Screenshots are not ideal, even though they’re simple.
If you want your floor plans removed again, just let me know.
Bauexperte
My question to you:
Andre
Hello Andre,
Bauexperte
Hello.
I think the integrated garage and its ceiling as a small terrace are fine. However, you should place the door to the garage from the hallway rather than from the party room (maybe leave out the second door in the middle). It would be inconvenient if you’re having a party and a slightly tipsy guest mistakes the door and suddenly stumbles over your car with a bottle in hand. Not to mention, you’d constantly have to walk through the party room every time you want to get to the car.
On the top floor, the left room is still quite narrow (just under 3m (10 feet), if I’m seeing that correctly), but it is long (over 5m (16 feet)). One possible solution would be to shift the outer wall all the way outwards, similar to the master bedroom (the ceiling above the terrace would then obviously need support, but that wouldn’t look bad at all and is definitely doable). Additionally, you could move the wall between the master bedroom and this room slightly so both spaces gain more area, while eliminating the awkward angled wall.
Zeiti
Zeiti
Thank you for the suggestions.
I will modify the door to the garage.
I have also considered moving the exterior wall of the children’s room in the attic outward. I’ll need to discuss with my architect whether this is feasible.
I will probably move the bathroom wall toward the dressing room and the dressing room wall toward the bedroom. The bedroom doesn’t need to be that large since I have a dressing room.
I’m not sure if it makes sense, but the front door could possibly open in the opposite direction. Advantage: You enter directly into the cloakroom.
Disadvantage: On the right side, you would face a wall – opening it towards the left, in the direction of the stairs, would create a more open feeling. Especially when there are several people (kids) involved, the first ones start undressing while the others are still outside – meaning the door is open, but there is no place to put down their belongings.
I like the latest version. However, I would suggest adding windows on the terrace side (to the west) in the living area, so you can get some evening sunlight there.
You can omit the dining area in the kitchen due to the adjacent table. Perhaps arrange the kitchen in a U-shape (opening facing down), with the left side not extending all the way to the wall to allow passage to the living room, creating more of a breakfast bar.
It might also be possible to enlarge the bathroom on the upper floor by reducing or removing the walk-in closet.
Thank you for the many suggestions. I think the idea with the front door is a good one. I hadn’t considered that before.
I still need to have the cost estimate calculated.
It will be between 250,000 and 300,000. A plot of land is already available.
I should mention that I am building in a rural area, where prices are somewhat lower than in the city.
