ᐅ Single-family house floor plan, 2 full stories, approximately 180 m², on a 600 m² plot of land
Created on: 6 Oct 2021 00:29
Masterle25
Hello dear members,
like most others, I have also been quietly following along for quite some time. There are many great pieces of advice here.
The building application has been submitted, and the exterior dimensions as well as the number of windows are fixed. Positioning is still negotiable in consultation, though only to a limited extent. Inside, we basically still have almost all options. The general contractor (GC) is a local family business and has been operating for over 20 years. They are consistently found in the surrounding new development areas, along with two other GCs, and their reputation is quite remarkable. (In fact, we spent quite some time interviewing the newly settled homeowners around us... *g*) One GC was excluded because of the building method (exclusively KfW 40+ standard), and another after submitting a proposal. The process so far has taken about 10 months, starting with graph paper, heating technology, necessary rooms, house positioning, and so on. There are great guides on this topic in the forum!
So, I hope these words were inviting enough to read through the list of questions. If I have forgotten anything, please let me know. I look forward to your feedback, critical comments are also welcome!
No development plan
Plot size – 598 sqm (6,435 sq ft)
Slope – no
Floor area ratio – 0.3
Building window, building line and boundary – 3 m (10 feet) distance on all sides
Other stipulations – orientation aligned with neighboring buildings
The building project, including documents, has already been approved by the relevant building authority.
Homeowners’ requirements
Style, roof type, building type – gable roof / 30° pitch facing south with a 10 kWp photovoltaic system, KfW 55 EE standard
Basement, floors – slab-on-grade foundation, 2 full floors, unheated attic
Number of occupants, ages – currently 3 people, planned 4; ages 38, 35, 1
Space requirements on ground floor and upper floor – Ground floor: living/dining, closed kitchen, study/guest room, WC/bathroom, utility/technical room, guest WC including shower
Upper floor: bedroom, dressing room (emergency room if 3rd child), 2 children’s rooms, bathroom
Office: 2 home office workstations
Guests per year: max. 5, excluding drunken friends, who usually make do with the couch *g*
Open or closed architecture: rather closed architecture
Conservative or modern construction: conservative
Open kitchen, island: closed kitchen, island only used as a workspace
Number of dining seats: 6
Fireplace: no
Music/speaker wall: TV wall
Balcony, roof terrace: none
Garage, carport: garage plus carport cover
Who created the plan:
Planner from a construction company, based on our draft floor plan
What do you particularly like? Why? All necessary rooms are present in sufficient size
What do you not like? Why? Office entrance difficult to use, lack of space due to guest WC and living room widening
Fixed price: approx. 450,000€
Personal price limit for house, including fittings: 550,000€
Preferred heating technology: air-to-water heat pump + underfloor heating
If you had to give up something, which details/extensions:
- can give up: size of the dressing room
- cannot give up: office / two children’s rooms
Why did the design turn out like it is now?
Which wishes were implemented by the planner?
- We have already planned and commissioned the kitchen; floor plan adjusted accordingly (changes still possible)
We hesitated a long time over open vs. closed kitchen and, after deciding, debated for a long time over whether to have a pantry behind the kitchen front or not; it is now behind sliding elements on the right side (see attachment)
- Storage space under the stairs
- Bedroom window removed on the east side because of bedroom closet
- Living room widened due to TV wall and to gain space
All rooms are suitable for everyday use, and living on the ground floor later with minimal alterations is possible
Are the individual rooms adequately lit? I have no sense of this at all. Any obvious flaws?
PS: North is at the top on the site plan as well as on both floor plans!
No development plan
Slope – no
Fireplace: no
Masterle25 schrieb:
Hm... I’m confused. I only need a room next door, right? You’re confused because those replies were not directed at you, see the quote.
Masterle25 schrieb:
No, the kitchen is even supposed to be closed off temporarily, That’s what I’m saying. Just not to you—I was replying to @miriam85 in general.
Masterle2516 Oct 2021 15:1311ant schrieb:
But visually for the façade, I’d prefer the other direction – the third broom cupboard can be placed elsewhere anyway.We will definitely revisit this with the kitchen planning. There is a refrigerator positioned at the bottom, so omitting a tall cabinet would need careful consideration. But maybe the dimensions can be adjusted. It would definitely make sense, although I’m really building more for myself than for the neighbors. Still, it should look neat for sure! A beam would be necessary anyway because of the thick bedroom wall – though offset – but I recommend using a lighter wall there upstairs (or have I already mentioned this?).No, at least I haven’t noticed it so far. I’m not even sure how much I can decide here myself or if the structural engineer will have the final say:According to the structural calculation, the interior walls will be built with hollow bricks (Poroton) of appropriate thickness or concrete walls.
Can you really recommend a thickness without calculations? I guess that would ultimately have to be reviewed during the construction planning, right?
Masterle25 schrieb:
But it should definitely look neat!At the moment it looks right-aligned.Masterle25 schrieb:
I’m not even sure how much I can decide here myself, or if the structural engineering will ultimately determine it: According to the structural calculation, the execution of the interior walls will be done with [...] [...] Can you recommend a thickness without a calculation at all?Without a calculation, I can say that a heavy wall (considered on its own), if it doesn’t have a similar load-bearing wall beneath it, represents a load for the floor structure below (which is lighter, of course). Whether it can be slimmer (depending on whether it is a beam or concrete floor above) is another matter. If so, I would choose 11.5 cm (4.5 inches) here or gypsum boards (10 cm (4 inches)).https://www.instagram.com/11antgmxde/
