ᐅ Floor plan for a single-family house, 130 sqm, hillside plot, 2 stories
Created on: 9 Dec 2021 19:09
Pitigliano
Attached is the questionnaire with the floor plan and plot details for discussion.
Plot size: 2200 sqm (0.54 acres)
Slope: South-facing slope, about 2.50 m (8 ft) within the building zone
Floor area ratio: §34 – adjacent properties have 1.5 to 2 stories with gable roofs
Plot ratio: §34
Building zone, building line, and boundary
Edge development
Roof type: 22-degree gable roof
Architectural style
Orientation: South-facing slope, accordingly oriented
Maximum heights / limits
Additional requirements
Architectural style, roof type, building type: Classic, gable roof, single-family house without projections
Basement, floors: No basement, but due to slope, the lower residential floor should be partially embedded into the hillside. Above that, the ground floor as a full story.
Number of occupants, ages: 2 adults (42 and 49), 1 child (19)
Space requirements on ground and upper floors: approximately 65 sqm (700 sq ft) each
Office: Family use or home office? No
Overnight guests per year: negligible
Open or closed layout: open on the ground floor
Conservative or modern construction:
Open kitchen with island: Yes, with island
Number of dining seats: 6
Fireplace: No
Music / stereo wall
Balcony, roof terrace: No
Garage, carport: Double garage preferred, carport acceptable if necessary
Utility garden, greenhouse
Additional wishes: Photovoltaics planned, mechanical ventilation system included in price, KfW55 energy standard
Planning source: DIY and general contractor planner
-Planner from construction company: Yes
-Architect: No
-Do-it-yourself: Yes
What do you especially like? Why? South orientation, view
What do you dislike? Why? That’s for you to tell us
Price estimate from architect/planner: 330,000
Personal price limit for house, including fittings: 450,000 including additional construction costs
Preferred heating technology: Air-to-water heat pump
If you have to give up on which details / expansions
-Can you do without: Garage
-Can’t do without: Not building smaller
Why did the design evolve as it is now? Example:
Information from the web (including this forum) and contacts with other builders
What makes it especially good or bad in your view? Don’t know
What is the most important / fundamental question about the floor plan summarized in 130 characters?
Because of this forum, the building shell is planned as it currently is. The lower residential floor is to be half embedded into the slope on the valley side. On the open side are the two bedrooms and the main entrance. To the right, the double garage, also partly embedded in the slope. In the slope are the utility room and a bathroom. The ground floor above is planned entirely for living, with terraces and garden access, plus a small bathroom.
Fire away and thank you all.
Plan top is north.
Site plan: green plot 162/163, surrounding plots, roads, and buildings.
Green area 162/163 on site plan, bordered by roads, surrounding plots and buildings visible.
Lower floor plan: bathroom, utility room, hallway, bedroom 1, bedroom 2; green marked room 12.
Apartment floor plan: green marked living area with hallway, shower/WC, and kitchen.
Pitiglianio
31 Mar 2023 23:37
In January, we purchased a display kitchen. Tiles will be selected soon. Changes requested by the general contractor have been limited so far. The only significant extra cost has been about 3000 euros for the electrical installation. Plumbing will probably be a bit more expensive as well.
Schmaler Bauflur mit linker Treppe, offenen Kabeln an der Decke und Tür am Ende.
Baustelle: neues Haus mit orange Ziegelwand, Flachdach-Kellerplatte, Bagger und Schläuche.
Unfertiger Innenraum einer Baustelle mit offener Decke, blaue Rohre auf dem Boden.
Rohbau eines Wohnzimmers: Person kniet und fotografiert; blaue Rohre am Boden, große Fensterfront.
Pitiglianio
31 Mar 2023 23:52
Unfinished construction work on a two-story house, supports, wooden beams, ladder; yellow car in front.
The slope stabilization around the property and house will be secured using granite blocks in visible areas and L-shaped retaining walls along the property boundaries. Unfortunately, these costs cannot be postponed and must be carried out gradually in the near future. Hopefully, the effort will remain manageable.
Pitiglianio
26 Oct 2023 17:17
Hello dear forum community,
here are some new photos of our construction progress.
At the beginning of April, the PUR floor insulation as well as the underfloor heating mats were installed. Afterwards, the cement screed was applied.
Empty space with packaged insulation material and insulation rolls for interior work
Underfloor heating pipes laid in a spiral shape on an insulation base during the construction phase.
Unfinished living space under construction: smooth concrete floor, loose cables, large window front.
The ceilings have been insulated and suspended.
Interior of a construction site: open ceiling with metal grid, insulation boards, tools, window view
Unfinished interior with large window fronts; construction equipment outside, cables and wooden strips inside the room.
Outside, we were able to continue working on the garage and install the slope stabilization behind the house with L-shaped concrete blocks.
Construction site: New house with flat roof waterproofing, excavator in the background.
Construction site on a slope: red brick house, concrete wall, construction equipment, and fencing.
Pitiglianio
26 Oct 2023 17:26
At the beginning of May, the house was scaffolded again, and the plasterers applied the base coat followed later by the finishing coat. I was a bit worried about discovering any imperfect work in the morning side light. Fortunately, the guys did a good job. 🙂
Two-story house with scaffolding, facade work, construction equipment, and gravel in the foreground
Modern house under construction with scaffolding, white facade, open garage, and building materials.
White, two-story house in shell construction with open garage and construction tools in front
The painter was already at work here and painted the house in the desired cappuccino tone.
At the same time, we were able to start inside with the wood-look tiles, installed in the living area and kitchen.
Renovation room with wood floor, gray accent wall, red background wall, and window front on the right.
Bright empty room with wood laminate floor; window front behind plastic foil; cables on the floor
Pitiglianio
26 Oct 2023 17:37
We have mostly kept the walls white, except for a gray wall in the dining/kitchen area and a burgundy wall in the living room. The bedrooms also received a colored accent wall. For the wall construction, we opted for (high-quality) Q2 finish with painter’s fleece.
Room with red wall, a ladder on wooden floor, renovation work.
Renovated interior with wooden floor, gray walls and red accent wall at the back.
Outside, there were further significant earthworks, and we were able to place the desired granite blocks around the house for slope stabilization, especially for the western terrace and garden. A staircase was also installed next to the garage leading up to the rear northern terrace.
White, two-story new build villa with carport; construction site with gravel, stones, and car.
White single-family house on a slope with solar panels on the roof, green surroundings.
As you can see, we also decided on photovoltaic systems, installing nearly 17 kWp on both sides of the roof. However, storage systems were too expensive for us.
Modern white single-family house on a stone wall made of boulders, SUV in front.
Modern white house with solar panels on gravel courtyard, surrounded by greenery.
We are mostly done with the general contractor. The final inspection has already taken place. Except for a few minor issues, all work is completed. However, there are still some tasks remaining outdoors, which we plan to address over the next few months.
Sunshine387
26 Oct 2023 18:00
You have chosen a very beautiful color tone for your house. It definitely looks more stylish than the classic white, and the view from your terrace must be fantastic. All that’s missing now is the infinity pool 😀
