ᐅ Floor Plan for Semi-Detached House on a Very Small Plot
Created on: 22 May 2014 16:34
O
OliverZ
I hope you can share your opinions on our floor plan for a semi-detached house on a very small plot.
If you have any questions, feel free to ask me.
2D floor plan of a house with entrance area, stairwell, hallway, and hobby room.
Floor plan of a house with kitchen, living room, foyer, and stairs
Detailed 2D floor plan of a house with stairs, bathroom, bedroom, and dressing room
Detailed floor plan of a house with stairwell and room layout
Doc.Schnaggls
23 May 2014 13:27
Hi OliverZ,
you could try experimenting a bit with the layout...
Maybe move or enlarge the bathroom to the right or left, up to the 2m (6.6 ft) line, and then plan the bedroom opposite it.
The walk-in closet could then possibly be designed not as a separate room, but for example as a niche under the sloping roof, visually separated with (glass) sliding doors...
If you leave out the hallway and place the bedroom door directly next to the staircase, you would gain significantly more space to move walls or partitions around.
Sure, a door right next to the stairs isn’t necessarily ideal, but given the relatively narrow width of the house, it might be a worthwhile alternative...
This way, you could effectively design the entire attic floor as a sleeping area with bathroom and walk-in closet (like a hotel suite) without losing valuable (because limited) space to a hallway.
Dirk
O
OliverZ
23 May 2014 13:33
Hello Dirk, I think the idea of having a door by the staircase is brilliant; it really creates a huge space.
Bauexperte
23 May 2014 13:48
Hello Dirk,
Doc.Schnaggls schrieb:
If, for example, you omit the hallway and place the bedroom door directly at the staircase, you gain significantly more space to move walls or partitions around. Admittedly, a door right next to the stairs isn’t exactly ideal...
This door is not only less than ideal but also would not be approved according to building regulations 😉
Regards, Bauexperte
O
OliverZ
23 May 2014 13:54
@Bauexperte May a layperson ask why?
Wastl
23 May 2014 14:21
Bauexperte schrieb:
Hello Dirk,
This door is "not only" far from ideal, but also technically "not" approved according to building regulations 😉
Regards, Bauexperte
It was constantly approved here. Personally, I don’t find it appealing, but our neighbor built it that way.
Bauexperte
23 May 2014 14:32
Wastl schrieb:
It was constantly approved for us. Personally, I don't think it's nice, but our neighbor built it that way.
"Constantly" built without planning permission will probably be closest to the truth; the typical regional variations are not that different after all. The building code states the following:
... a staircase must not start immediately behind a door. There must be a stair landing between the door and the stairs, which should be at least as deep as the door is wide. Larger depths of the stair landing may be required depending on the direction of the staircase.
If your neighbor received her building permit / planning permission through the simplified approval process, her architect is responsible with his signature on the building application to ensure that all regulations were followed 😉
Best regards, Bauexperte
