ᐅ Floor Plan Review Single-Family Home with Basement on a Gentle Slope
Created on: 8 Dec 2020 21:21
Kuzorra
after following along for a long time and reading through various threads and comments, I’m now stepping forward with our current planning status and hope for brutally constructive feedback. Of course, I followed the example of @ypg...
Fortunately, we have “access” to a family-owned plot. The old house needs to be demolished, and we want to rebuild roughly in the same spot. Setback distances are sufficient on all sides.
Plot size: approx. 900m² (9700 sq ft) with a slight slope
Number of parking spaces: existing double garage (old) remains for now
Number of floors: II allowed
Roof shape: gable roof specified, 40–50°
Maximum heights / limits: 3.25 m (10.7 ft) uphill side, 5.50 m (18 ft) downhill side
Homeowners’ Requirements
Basement, floors: full basement (partly used as living space), ground floor, attic floor
Number of occupants: 4 persons (2 adults + 2 toddlers)
Office: increasingly home office (both parents)
Overnight guests per year: 2–5 people, 3–10 visits per year (if not during COVID)
Open kitchen: yes, with a “half” cooking island
Number of dining seats: 6–8
Fireplace: no
Additional wishes / special features / daily routine, also reasons why some things are or aren’t included: We have planned a small pantry/storage room because we are used to it and find it very practical. The kitchen is already largely designed around our practical needs. The children’s rooms should be the same size because my wife is very traumatized by always having had the smaller room. ;-)
Who designed the plan: originally based on a standard model from a builder, but ultimately custom-designed (with the builder). We have already scaled back from much larger original plans and saved a total of 20 m² (215 sq ft).
What do you like particularly? Why? We already like a lot as it is. For example, the terrace is on the “pleasant” side and accessible from the kitchen and dining room. The ground-level basement exit uses the slope to provide offices (or guest room) with plenty of daylight. We don’t need a huge wellness area in the attic; a compact bathroom is sufficient. A walk-in closet would only be nice to have, but we skipped it and made sure there is enough space for our large wardrobes.
What don’t you like? Why? At the moment we are quite satisfied.
Price estimate according to architect/planner: €320,000 (we have already included as many options as possible in an initial sample selection). A finished basement will add around €50,000–60,000 (we are currently waiting for the soil survey results).
Personal price limit for the house, including fittings: please not too much ;-)
Preferred heating technology: air-to-water heat pump (gas is basically available but inconveniently located relative to the house. Furthermore, a photovoltaic system should eventually help supply the heat pump).
What details / expansions can you do without?
- can do without: photovoltaic system for now (roof and wiring will be prepared for it), centrally controlled ventilation system is too expensive for us, probably will take compromises on the staircase flooring and choose the second most expensive and second nicest solid wood floor.
- cannot do without: basement, second bathroom on the ground floor.
Why did the design turn out like it did? We researched a lot ourselves (catalogs, show homes, friends and relatives, and our current apartment) and worked through several iterations of the plan together with the builder.
The main living area will probably always be the open living/dining room, but the kids should have enough private retreat space in their own bedrooms. Optionally, home office and children’s rooms could be swapped later.
What do you think makes the design especially good or bad? The design covers what we imagine and we currently see no shortcomings.
Are we overlooking anything important? Any tips regarding the outdoor areas?
We have been a bit careless about the outdoor areas so far but have now contacted landscaping professionals. The parents-in-law live in house number 31, towards which we plan to orient the terrace. Additionally, there will be another seating area toward the barn (with afternoon/evening sun), but this is on the “lower level”. The outdoor unit of the air-to-water heat pump is located towards the neighbor at number 35. At the front entrance, 3 m (10 ft) must remain free to the neighboring property, which can also be used occasionally as a parking spot (but this should not be the main parking space).
Basement floor plan with cellar 1, utility room, front cellar, guest and home office.
Ground floor plan: kitchen, hallway, shower and open living/dining area.
Upper floor plan: three bedrooms (parents lower right, two upstairs), bathroom, corridor.
Section through a multi-story house with attic, ground floor, basement, stairs and 40° roof pitch.
Site plan: red boundary line, buildings with barn, double garage, new entrance, higher/lower elevation.
10 Dec 2020 00:36
You, we don’t know the topography.
Anyway: I wouldn’t build against the southern sun. It was just a suggestion. If that works for you, then it’s fine as is.
Kuzorra10 Dec 2020 00:42
Due to the sloping terrain, we are a bit limited in that regard....
O
Olli-Ka
10 Dec 2020 09:44
Würfel* schrieb:
I would swap the door and the washbasin in the guest bathroom to make better use of the space.
good idea, we will probably change it like that too.
Olli
Schimi179110 Dec 2020 10:43
Teilung schrieb:
I also find the design very successful. I was wondering if small storage rooms might be missing on the upper and ground floors, since otherwise you have to constantly go down to the basement or up to the attic.
Yes, the space needed for "stuff" should not be underestimated 🙂
Kuzorra10 Dec 2020 11:44
That's right.
That's why the kids get large rooms, so at least they have to manage their own "stuff" nicely themselves ;-)
Michilo
10 Dec 2020 12:39
I am always a fan of positioning doors so that a closet can fit behind them. This would be easily possible in the children's rooms. This way, dead space becomes potential storage for "stuff" 🙂
