ᐅ Floor plan design shortly before submitting the building permit application
Created on: 2 Oct 2017 23:25
R.Hotzenplotz
Hello everyone!
As some users have requested before, I’m now starting a new thread with the current planning of our detached house, which is about to be finalized.
These are the preliminary drawings for the building permit / planning permission application, and I have one last chance to review them and point out any issues.
It still seems to me that there is less than 1.20m (4 feet) of space between the two wardrobes in the dressing room. Or am I seeing this wrong? Apparently, the rooms on the left and right were overlooked and not adjusted accordingly.
Two Velux ceiling spotlights are still planned to illuminate the upper floor hallway.
In the basement, on the right side in the upper room, a window similar to the one on the left basement side is an option.
We still haven’t decided on the T30 fire-rated door to the garage, even though it is shown in the plans. Most likely, for safety reasons and the limited use of the kitchen at the other end of the house, we will eventually forgo it.
User 11ant pointed out that the right window in child’s room 2 is suboptimally positioned. However, this could still be changed after submitting the building permit / planning permission application. Our architect thinks moving the window to the left would negatively affect the house’s exterior appearance. We’ll have to see about that.
Grundriss Kellergeschoss mit 3 Kellerräumen, Abstellraum, Flur, Haustechnik und Treppe.
Grundriss eines Hauses mit Keller, Flur KG, Haustechnik KG, Abstellraum KG und Treppen
Grundriss eines Hauses: Garage, Büro, Garderobe, Diele, WC, Küche, Wohn-/Essbereich.
Grundriss Dachgeschoss: Schlafzimmer, Ankleide, Bad, Dusche, zwei Kinderzimmer, Flur HWR Dachterrasse
Technischer Grundriss: Zentraler, ungenutzter DG-Bereich (193 m²) mit umlaufenden Dachschrägen.
Schnitt durch mehrstöckiges Wohnhaus mit Keller, Treppe, Dachkonstruktion und Maßlinien.
Moderne Wohnhausansicht: zweigeschossiges Gebäude mit Garage links und großen Fenstern.
Architektonischer Haus-Elevationsplan: Keller bis Dachgeschoss, Dach, Fenster, Geländeprofil.
Moderne zweigeschossige Hausansicht mit Flachdach, Balkonen, großen Fenstern und Garage.
Zweistöckiges Haus mit dunkler Fassade, grauem Dach, Balkon rechts und Garten mit Bäumen.
R.Hotzenplotz
10 Sep 2018 01:00
I am not aware of any slope. It also makes little sense since there is no drainage.
tomtom7910 Sep 2018 01:19
There definitely needs to be a slope. Drainage will then be handled externally via a trench drain or an additional slope leading to the street, but since that is not permitted, a channel drain must be installed there instead.
Alex85
10 Sep 2018 06:25
As if the mysterious 2% would allow a single drop of water to flow anywhere. Especially not on a rough surface.
As long as no one wants to wash their car in the garage, the registered water volume is anyway not enough to cause any drainage.
Climbee10 Sep 2018 07:56
Well, when the car is covered in snow and has large blocks of ice in the wheel wells during winter and is parked in the garage, you can end up with a small flood. I would definitely recommend a slope and the channel mentioned by Tomtom.
Alex85
10 Sep 2018 08:05
Calculate the required slope first to ensure proper drainage... I’m also not sure what kind of snow volumes are expected there. I would say those are exceptional events.
By the way, you’ll still have dirt.
The gate must be left slightly open; otherwise, water won’t drain there either, and freezing will be the next problem.
A channel directly behind the gate is nonsense anyway. Either the driveway paving is permeable, or the entire driveway is drained along the property boundary with a channel. A channel in front of the gate only makes sense if the driveway slopes towards the garage, which should really be the exception.
11ant10 Sep 2018 13:18
So, the plan (via private message I have a bit more than the excerpts in the threads) shows that the garage floor has no slope, the driveway slopes down towards the garage, and there is a channel in front of the gate. However, this plan also shows that both gates are the same height (top, bottom, and clear passage height). This means snow would accumulate across the entire surface — good thing we initially left out the pedestrian door.
