ᐅ Floor Plan Optimization for Urban Villa + Considerations for Land Elevation
Created on: 31 Jan 2020 13:29
Shiny86
Plot size 492 sqm (5293 sq ft)
Slope yes
Site coverage ratio?
Floor area ratio?
Building envelope, building line, and boundary?
Boundary development?
Number of parking spaces 2
Number of floors 2
Roof type Pyramid roof, 25 degrees
Architectural style Modern urban villa
Orientation Main entrance facing north
Maximum heights/limits
Additional requirements?
Clients’ Requirements
Modern urban villa with pyramid roof, 25 degrees
Basement, floors 2 full floors without basement
Number of occupants 4
Open kitchen, kitchen island
Number of parking spaces 8-10
Garage
Who designed it?
-Architect
Large living area, master bathroom
What don’t you like? Why?
Utility room quite small and master bedroom small, children’s room somewhat too large
The architect implemented the corresponding wishes
What do you think is especially good or bad about it?
Good: large living area
I am uncertain about the half-height window sizes and the swing direction of the doors
What do you think about the floor plans?
Slope yes
Floor area ratio?
Number of floors 2
Garage
Who designed it?
-Architect
- Where could it still be optimized? Would you recommend different window dimensions or sill heights?
- What do you think is poor or what would you do differently?
- A partition wall will be added in the walk-in closet. That would theoretically allow watching TV from the bed. I am considering a lightweight wall. I plan to place a 211cm (83 inches) Pax combination wardrobe in the closet. The closet is planned with a raw width of 218cm (86 inches). Do you think 218cm is enough for the Pax once the walls are plastered, or how wide should the rough dimensions preferably be?
- Is the hallway on the ground floor too narrow?
- Would you raise the ground level? The house would be 40cm (16 inches) below street level. If I build a terrace into the garden, it would be about 1m (3 ft) difference. You could raise only the house level, resulting in approximately 1.6m (5 ft) difference between terrace and garden. I don’t know anyone living below street level. Raising the garden would probably not be allowed without permits, and affected neighbors likely wouldn’t agree. On the sides of the house adjacent to neighbors, raising is permitted only up to certain limits. I am overwhelmed with the decision.
- Do you have any ideas for arranging the sofa differently and placing the TV sensibly? My husband doesn’t want the sofa back facing a window. I still need to get used to placing the sofa in the middle of the room.
- Is the kitchen size sufficient for a nice kitchen with an island?
Bertram100 schrieb:
Isn’t there a way to use the square meters of the open space more effectively? It looks nice as it is, but when the budget is tight, you have to make some adjustments. There’s a lot of space between the kitchen and dining table that’s mostly just circulation area, nothing else. But I don’t really have any ideas. Yes, I’ve thought about that too. I definitely plan to create two seating spots at the island so that the space in the middle has more purpose. I’ve read that you should allow about one meter (3 feet) for seating areas. I’m also planning a larger dining table for 8 to 10 people, though I’m not very familiar with dining table options yet. It should definitely be longer though.
Pinky0301 schrieb:
Is there really that much or frequent visiting that a sofa bed is necessary? If it’s just one person, maybe a fold-out armchair would work, or the living room sofa could serve as a sleeping spot. Or the kids could share a room for a while, and so on—there are more than one possibility. That way, the office can truly be used only as an office and storage space. Yes, you’re right. It doesn’t necessarily have to be a sofa. I can also use the office as a storage room. I’m flexible there. What window size would you find nice for that room?
On the north side, there will be an 88cm by 126cm (35in by 50in) window. Which window would you put on the west side?
Do you think creating a niche for a wardrobe would spoil the room?
One argument against having a wardrobe there instead of an office is that the living room layout—because of the sofa and TV placement—is quite good as it is. I wouldn’t make it any narrower just to give some space to the office.
If I were to put a wardrobe there, 4 meters (13 feet) in length would be too long. So I would rather put a guest toilet plus wardrobe there. But the idea of having the guest toilet right next to the sofa corner bothers me as well.
Pinky0301 schrieb:
How wide is the hallway again?1.82 m (6 feet). Do you think that's narrow?
It gets 60 cm (2 feet) wider towards the stairs.
Bertram1008 Apr 2020 10:30Speaking of the hallway: an unconventional (or rather Swedish) idea is that the front door could open outward. This way, the entire hallway area near the door—which, based on experience, is the most chaotic, cluttered, and frequently used part—becomes fully usable.
Alessandro schrieb:
the only option I see for youYou cannot see anything there. Because: when someone adds a suggestion here, the original poster replies: that’s nice, but unfortunately that floor plan is no longer valid; the valid version is still to come, which would be similar but quite different. Alessandro schrieb:
1. No one uses shoe racks. They just get left wherever shoes were taken off.No. Shoecabinets aren’t used because opening a flap makes them less accessible. Shoeracks, however, are used—best placed under the seating area for putting on and taking off shoes. Alessandro schrieb:
2. You URGENTLY need storage space, not just for clothes, shoes, etc.
3. A home office/guest room is a luxury I just don’t see working in your house or being realistically feasible.These two points are closely linked: on one hand, with only two children, a home office with a guest bed is certainly possible; on the other hand, due to a lack of other storage space, it must also serve as a utility room function—possibly in combination with the technical room/utility room where cleaning supplies are stored. Pinky0301 schrieb:
If the home office will be used regularly or permanently, having a dedicated room is important for tax purposes. Are there not specific rules for that? Does it meet the minimum size for it to be tax-deductible? Or do I remember that wrong?For tax purposes, a home office must not be a walk-through room and ideally should not contain personal files. From a building regulation standpoint, it is simply considered a living space. There are no size requirements under tax law; only the workplace ordinance mentions "adequate" size, which most employers interpret as no less than 8 sqm (86 sq ft). Unfortunately, there is no official “home office standard.” Shiny86 schrieb:
There will be an 88 x 126 cm (35 x 50 inch) window on the north side.“Northern light is never visible” practically means: only diffuse (indirect) light will come through there, and it will be weaker. Combined with a narrow window, it will only be bright enough until shortly after noon in winter to work without additional artificial lighting.https://www.instagram.com/11antgmxde/
Alessandro8 Apr 2020 13:20Unfortunately, I see misplaced priorities in the design. The office could be combined with storage room, pantry, and wardrobe through clever wall positioning. The main thing is that a total of 13 sqm (140 sq ft) on the upper floor is sacrificed for a dressing room and master bathroom. :eek _O
