ᐅ Floor Plan Optimization for Urban Villa + Considerations for Land Elevation
Created on: 31 Jan 2020 13:29
Shiny86
Plot size 492 sqm (5293 sq ft)
Slope yes
Site coverage ratio?
Floor area ratio?
Building envelope, building line, and boundary?
Boundary development?
Number of parking spaces 2
Number of floors 2
Roof type Pyramid roof, 25 degrees
Architectural style Modern urban villa
Orientation Main entrance facing north
Maximum heights/limits
Additional requirements?
Clients’ Requirements
Modern urban villa with pyramid roof, 25 degrees
Basement, floors 2 full floors without basement
Number of occupants 4
Open kitchen, kitchen island
Number of parking spaces 8-10
Garage
Who designed it?
-Architect
Large living area, master bathroom
What don’t you like? Why?
Utility room quite small and master bedroom small, children’s room somewhat too large
The architect implemented the corresponding wishes
What do you think is especially good or bad about it?
Good: large living area
I am uncertain about the half-height window sizes and the swing direction of the doors
  • Where could it still be optimized? Would you recommend different window dimensions or sill heights?
  • What do you think is poor or what would you do differently?
  • A partition wall will be added in the walk-in closet. That would theoretically allow watching TV from the bed. I am considering a lightweight wall. I plan to place a 211cm (83 inches) Pax combination wardrobe in the closet. The closet is planned with a raw width of 218cm (86 inches). Do you think 218cm is enough for the Pax once the walls are plastered, or how wide should the rough dimensions preferably be?
  • Is the hallway on the ground floor too narrow?
  • Would you raise the ground level? The house would be 40cm (16 inches) below street level. If I build a terrace into the garden, it would be about 1m (3 ft) difference. You could raise only the house level, resulting in approximately 1.6m (5 ft) difference between terrace and garden. I don’t know anyone living below street level. Raising the garden would probably not be allowed without permits, and affected neighbors likely wouldn’t agree. On the sides of the house adjacent to neighbors, raising is permitted only up to certain limits. I am overwhelmed with the decision.
  • Do you have any ideas for arranging the sofa differently and placing the TV sensibly? My husband doesn’t want the sofa back facing a window. I still need to get used to placing the sofa in the middle of the room.
  • Is the kitchen size sufficient for a nice kitchen with an island?
What do you think about the floor plans?
Floor plan of a single-family house: living/dining area, kitchen, hallway, storage room, cloakroom, WC.
Floor plan of a family home: CHILD 1, CHILD 2, PARENTS, WALK-IN CLOSET, BATHROOM, SHOWER/BATHROOM, HALLWAY.
Architectural drawing: two-story residential house with garage; southwest and northeast views.
Two facade views of a house: northwest and southeast with roof, windows, terrace, and garage.
Pinky030125 Feb 2020 18:24
I believe the access to the shower in the master bathroom is too narrow because of the toilet placed right in front of it. For both showers, I don’t see a way to omit the door. As I mentioned before, the door will have to be quite long. In the kids’ bathroom, I don’t like that the toilet is visible directly from the door. I would swap it with the sink for better privacy.
I’m concerned that the bedroom, at just over 3m (10 feet) wide, might be too narrow. How wide is your bed? It will probably fit better if the bed is placed against the wall at the bottom of the plan.
Shiny86
25 Feb 2020 19:06
Yes, I agree about the bathrooms. Maybe I should go through some building catalogs and see how they usually arrange them.
The bed with the frame is 2 meters (6 ft 7 in) long, but it’s old. I would buy the next bed at 1.8 meters (5 ft 11 in) eventually. Changing the bed’s position is difficult because of the window symmetry issue.
Curly
25 Feb 2020 19:32
With a 1.80 m (5 ft 11 in) wide bed (plus frame, probably 1.88 m (6 ft 2 in) wide), you don’t even have 60 cm (24 inches) of space between the bed and the wall. Isn’t that too tight for you? Personally, I wouldn’t go below 80 cm (31.5 inches) — even that’s not very generous.
Sabine
Shiny86
25 Feb 2020 19:38
I would buy a box spring bed without a frame. That way, the height would already be 60cm (24 inches) for everyone.
Pinky030125 Feb 2020 21:38
We have a box spring bed, which is still wider than the "mattress."
11ant25 Feb 2020 22:57
Shiny86 schrieb:
Rearranging the bed is inconvenient because of the window symmetry issue.
You can easily do without basing your luck on window symmetry (why specifically on this side of the house, anyway?).
