ᐅ Floor Plan Optimization for Urban Villa + Considerations for Land Elevation
Created on: 31 Jan 2020 13:29
Shiny86
Plot size 492 sqm (5293 sq ft)
Slope yes
Site coverage ratio?
Floor area ratio?
Building envelope, building line, and boundary?
Boundary development?
Number of parking spaces 2
Number of floors 2
Roof type Pyramid roof, 25 degrees
Architectural style Modern urban villa
Orientation Main entrance facing north
Maximum heights/limits
Additional requirements?
Clients’ Requirements
Modern urban villa with pyramid roof, 25 degrees
Basement, floors 2 full floors without basement
Number of occupants 4
Open kitchen, kitchen island
Number of parking spaces 8-10
Garage
Who designed it?
-Architect
Large living area, master bathroom
What don’t you like? Why?
Utility room quite small and master bedroom small, children’s room somewhat too large
The architect implemented the corresponding wishes
What do you think is especially good or bad about it?
Good: large living area
I am uncertain about the half-height window sizes and the swing direction of the doors
What do you think about the floor plans?
Slope yes
Floor area ratio?
Number of floors 2
Garage
Who designed it?
-Architect
- Where could it still be optimized? Would you recommend different window dimensions or sill heights?
- What do you think is poor or what would you do differently?
- A partition wall will be added in the walk-in closet. That would theoretically allow watching TV from the bed. I am considering a lightweight wall. I plan to place a 211cm (83 inches) Pax combination wardrobe in the closet. The closet is planned with a raw width of 218cm (86 inches). Do you think 218cm is enough for the Pax once the walls are plastered, or how wide should the rough dimensions preferably be?
- Is the hallway on the ground floor too narrow?
- Would you raise the ground level? The house would be 40cm (16 inches) below street level. If I build a terrace into the garden, it would be about 1m (3 ft) difference. You could raise only the house level, resulting in approximately 1.6m (5 ft) difference between terrace and garden. I don’t know anyone living below street level. Raising the garden would probably not be allowed without permits, and affected neighbors likely wouldn’t agree. On the sides of the house adjacent to neighbors, raising is permitted only up to certain limits. I am overwhelmed with the decision.
- Do you have any ideas for arranging the sofa differently and placing the TV sensibly? My husband doesn’t want the sofa back facing a window. I still need to get used to placing the sofa in the middle of the room.
- Is the kitchen size sufficient for a nice kitchen with an island?
I would skip the children's bathroom. Instead, plan for a spacious bathroom that is enjoyable to use every time you enter. A second shower can then be for guests and as an alternative on the ground floor. The money can be better spent elsewhere, and you also have to clean everything. This way, you might even have an extra small room upstairs for storage or something similar.
haydee schrieb:
The shower bathroom downstairs is not suitable for seniors with limited mobility (and if you can no longer manage the stairs, then that applies to you). How do you plan to separate the living room?
I think three bathrooms are too many. Especially since, apart from the children's rooms, there is a lack of space everywhere.
Make sure to add a window on the other exterior wall in the children's rooms. Especially in summer, if one window is shaded, the other can be opened to let in light. Why is the shower bathroom not suitable for seniors with limited mobility?
Simply put up a wall to the left in the living room when you enter.
Okay, the point about windows in summer makes sense. I still don’t know how large to make all the windows.
Someone once wrote here that we should make all windows 1 meter wide (about 3 feet). Isn’t that too large for the utility room, the bathroom downstairs, and the walk-in closet?
Shiny86 schrieb:
The living room door swings to the left because we don’t want any wall on the right side (see post #1), so the door can’t hit anything on that side. He just took that wall section from your design. What’s the advantage of having that wall section? Or is it just a matter of taste? That section is exactly for the door stop; it also provides a small visual barrier from the kitchen and allows for a kitchen shelf to fit nicely into the corner (for example, for cookbooks or spices).
Shiny86 schrieb:
3. The shower is correct. This is so we can still live here when we’re older. If there’s no bedroom or guest room downstairs, I think that’s unnecessary. But if it’s that important to you, that’s fine. I would prioritize the space for the coat rack. You won’t use the shower for 40 years. By the time you need it, the bathroom will have to be renovated anyway. Then you can move the wall and add the shower later more easily. Unless, of course, you have a large dog moving in who needs to be washed there regularly.
Shiny86 schrieb:
Wall in front of the stairs: Oh my God, does it go all the way up to the ceiling???
I’m picturing a half-height masonry railing about 1 meter (3.3 feet) high, or whatever the standard height is. Isn’t that supposed to be a half wall? How high should it be? That’s not clear from the drawing. Usually, a half-height wall is shown with a different color, dashed lines, or is labeled directly. If the wall is meant to be half-height, then it should be fine.
I'll double-check about the half-height wall.
The other two points make me think. Thank you! Especially that the shower can be easily retrofitted. Is it always possible to retrofit, or do we need to plan the connections in advance to ensure it can be added later? I’m not familiar with this.
Shiny86 schrieb:
So that we can still live there in old age.There are stairlifts, too! I never understand why many home builders plan to live only on the ground floor when they get older, especially since it often has to be renovated for that purpose. When the time comes that I absolutely cannot manage the stairs anymore, what use is the house to me then? At least, that’s how I see it...
