ᐅ Floor Plan Optimization for Urban Villa + Considerations for Land Elevation
Created on: 31 Jan 2020 13:29
Shiny86
Plot size 492 sqm (5293 sq ft)
Slope yes
Site coverage ratio?
Floor area ratio?
Building envelope, building line, and boundary?
Boundary development?
Number of parking spaces 2
Number of floors 2
Roof type Pyramid roof, 25 degrees
Architectural style Modern urban villa
Orientation Main entrance facing north
Maximum heights/limits
Additional requirements?
Clients’ Requirements
Modern urban villa with pyramid roof, 25 degrees
Basement, floors 2 full floors without basement
Number of occupants 4
Open kitchen, kitchen island
Number of parking spaces 8-10
Garage
Who designed it?
-Architect
Large living area, master bathroom
What don’t you like? Why?
Utility room quite small and master bedroom small, children’s room somewhat too large
The architect implemented the corresponding wishes
What do you think is especially good or bad about it?
Good: large living area
I am uncertain about the half-height window sizes and the swing direction of the doors
  • Where could it still be optimized? Would you recommend different window dimensions or sill heights?
  • What do you think is poor or what would you do differently?
  • A partition wall will be added in the walk-in closet. That would theoretically allow watching TV from the bed. I am considering a lightweight wall. I plan to place a 211cm (83 inches) Pax combination wardrobe in the closet. The closet is planned with a raw width of 218cm (86 inches). Do you think 218cm is enough for the Pax once the walls are plastered, or how wide should the rough dimensions preferably be?
  • Is the hallway on the ground floor too narrow?
  • Would you raise the ground level? The house would be 40cm (16 inches) below street level. If I build a terrace into the garden, it would be about 1m (3 ft) difference. You could raise only the house level, resulting in approximately 1.6m (5 ft) difference between terrace and garden. I don’t know anyone living below street level. Raising the garden would probably not be allowed without permits, and affected neighbors likely wouldn’t agree. On the sides of the house adjacent to neighbors, raising is permitted only up to certain limits. I am overwhelmed with the decision.
  • Do you have any ideas for arranging the sofa differently and placing the TV sensibly? My husband doesn’t want the sofa back facing a window. I still need to get used to placing the sofa in the middle of the room.
  • Is the kitchen size sufficient for a nice kitchen with an island?
What do you think about the floor plans?
Floor plan of a single-family house: living/dining area, kitchen, hallway, storage room, cloakroom, WC.
Floor plan of a family home: CHILD 1, CHILD 2, PARENTS, WALK-IN CLOSET, BATHROOM, SHOWER/BATHROOM, HALLWAY.
Architectural drawing: two-story residential house with garage; southwest and northeast views.
Two facade views of a house: northwest and southeast with roof, windows, terrace, and garage.
Shiny86
25 Jun 2020 23:25
haydee schrieb:
What do you want to do with the rest of the garden? Level it?
Actually, yes. Is that common for gardens like this, or do people usually just live with the natural terrain?
I think it would be better for the kids and their play equipment. The children are still small, and the toddler paddling pools will initially stay on the terrace. But the pools will definitely get bigger over time, etc.
By the way, that’s still 150 sqm (1,615 sq ft) of garden we will have. I’m curious to see how it will turn out.
Smialbuddler schrieb:
You wouldn’t believe what a digger can quickly fix with your current planned fill.
Thanks. I hadn’t really thought about it that way. I always assumed I’d have to build exactly as approved. But you’re right, it’s not as irreversible as “wrong” decisions during the structural shell stage.
Does nobody really check afterward what has been done with the terrace, garden shed, and carport?
I don’t understand all the regulations if no one enforces them. But I’m not complaining.
Shiny86
25 Jun 2020 23:29
pagoni2020 schrieb:
I believe that you can first establish a basic foundation
Yes, you’re right about that. That should be the goal.
The 15cm (6 inches) difference between the house finished floor level and the terrace is probably not important at this stage. If it were really an issue, we probably wouldn’t get a building permit / planning permission either. And if necessary, you can always add fill or remove material later.
pagoni2020
25 Jun 2020 23:42
For example, we will have a terrace, and the rest of the property is mostly flat or will be leveled at the end. Just plant grass and that’s it. If you start with elaborate garden design, it can quickly become over the top or look like what you often see in garden showrooms. You can put a paddling pool or similar right in the middle of the lawn, or let the kids decide. Don’t try to create a showcase garden—keep it simple. That saves money and nerves, but unfortunately, it will only earn you a lower rank in the unspoken neighborhood competition of having the most impressive (usually ugliest) garden.
We always added to ours gradually, with mostly simple yet affordable ideas. For example, you can just lay down wooden beams as borders instead of concreting flower beds or similar. Less is often more.
Wait and see what the children actually enjoy. Maybe it will be a tent that they want to move around all the time, or a tent village instead of a slide, or the leftover mound of earth might be more exciting than some fancy play equipment from a showroom.
If you do it this way, you can keep changing things and won’t have permanent concrete structures standing around.
I once saw someone who had an old tram car in their garden, using it as a coffee spot, or an old rusty VW bus deliberately used as decoration. Be bold, even a bit crazy, in a way that suits you, and don’t let anyone else define your taste.
If not in your own garden, where else should you be able to relax without worry?
When your neighbor looks away with disdain, that’s a strong sign that you’ve created something great for yourself.
haydee
26 Jun 2020 01:37
The outdoor area develops over time. I probably wouldn’t add a large amount of fill all at once.
For the perennial bed, it doesn’t matter if it’s flat or sloped. A slide, water slide, or climbing area works very well on a slope. Filling in perfectly straight and aggressively costs money, especially since you also need proper retaining measures.
Shiny86
9 Jul 2020 00:06
Quick question:
Are interior door heights relevant for the building permit / planning permission?
I have all the application documents in front of me and suddenly notice in section A-A that the doors on the upper floor are 2.01 meters (6 ft 7 in) high instead of 2.135 meters (7 ft).
Can this be easily changed after the building permit is approved, or will it become complicated if I submit it like this?
The agreed doors on the ground floor and upper floor were supposed to be 2.135 meters (7 ft) high.
Alessandro
9 Jul 2020 08:51
Interior doors do not matter for the building permit / planning permission.
