ᐅ Floor Plan Optimization for Urban Villa + Considerations for Land Elevation
Created on: 31 Jan 2020 13:29
Shiny86
Plot size 492 sqm (5293 sq ft)
Slope yes
Site coverage ratio?
Floor area ratio?
Building envelope, building line, and boundary?
Boundary development?
Number of parking spaces 2
Number of floors 2
Roof type Pyramid roof, 25 degrees
Architectural style Modern urban villa
Orientation Main entrance facing north
Maximum heights/limits
Additional requirements?
Clients’ Requirements
Modern urban villa with pyramid roof, 25 degrees
Basement, floors 2 full floors without basement
Number of occupants 4
Open kitchen, kitchen island
Number of parking spaces 8-10
Garage
Who designed it?
-Architect
Large living area, master bathroom
What don’t you like? Why?
Utility room quite small and master bedroom small, children’s room somewhat too large
The architect implemented the corresponding wishes
What do you think is especially good or bad about it?
Good: large living area
I am uncertain about the half-height window sizes and the swing direction of the doors
  • Where could it still be optimized? Would you recommend different window dimensions or sill heights?
  • What do you think is poor or what would you do differently?
  • A partition wall will be added in the walk-in closet. That would theoretically allow watching TV from the bed. I am considering a lightweight wall. I plan to place a 211cm (83 inches) Pax combination wardrobe in the closet. The closet is planned with a raw width of 218cm (86 inches). Do you think 218cm is enough for the Pax once the walls are plastered, or how wide should the rough dimensions preferably be?
  • Is the hallway on the ground floor too narrow?
  • Would you raise the ground level? The house would be 40cm (16 inches) below street level. If I build a terrace into the garden, it would be about 1m (3 ft) difference. You could raise only the house level, resulting in approximately 1.6m (5 ft) difference between terrace and garden. I don’t know anyone living below street level. Raising the garden would probably not be allowed without permits, and affected neighbors likely wouldn’t agree. On the sides of the house adjacent to neighbors, raising is permitted only up to certain limits. I am overwhelmed with the decision.
  • Do you have any ideas for arranging the sofa differently and placing the TV sensibly? My husband doesn’t want the sofa back facing a window. I still need to get used to placing the sofa in the middle of the room.
  • Is the kitchen size sufficient for a nice kitchen with an island?
What do you think about the floor plans?
Floor plan of a single-family house: living/dining area, kitchen, hallway, storage room, cloakroom, WC.
Floor plan of a family home: CHILD 1, CHILD 2, PARENTS, WALK-IN CLOSET, BATHROOM, SHOWER/BATHROOM, HALLWAY.
Architectural drawing: two-story residential house with garage; southwest and northeast views.
Two facade views of a house: northwest and southeast with roof, windows, terrace, and garage.
Crossy
27 May 2020 20:10
Yes, that is possible. We have done that as well.
Shiny86
27 May 2020 20:14
Crossy schrieb:
Yes, that’s possible. We did the same.
Could you tell me what changes you made?
There must be limits, right?
I can’t really imagine what is allowed and what isn’t.
11ant27 May 2020 20:16
It’s best to get a set of ten permits from the building authority for any further changes, because these probably won’t be your last two. Right now, I’m mentally sitting at your dining table and realize I’d have to get up and measure again to be sure that the 176mm (7 inches) window is actually narrower than the 201mm (8 inches) one leading to the terrace. Are you aware that the draftsman, because of your bathroom window, could by now plead for “justifiable homicide on demand”? – now just roll the dice already!!! – it won’t get any more perfect than this.
Crossy
27 May 2020 21:17
We changed the parapet heights and made four windows 12.5cm (5 inches) narrower.
But whether you install a 2m (6 ft 7 in) French casement window or a 3m (9 ft 10 in) lift-and-slide door element, the building authority does not mind.
Shiny86
28 May 2020 00:47
It's best to get a ten-ticket card for further changes from the building authority right away, because these probably won’t be your last two. In my mind, I’m sitting at your dining table and realize I’d have to get up and measure again to be sure that the 176mm (7 inches) window is actually narrower than the 201mm (8 inches) one facing the terrace. You do realize that because of your toilet window, the draftsman could now plead "manslaughter on demand"? — so just roll the dice already!!! It won’t get any more perfect than this.
You are wonderfully honest and straightforward.
And it’s true. I probably can’t plan it any better. Just differently, but probably not better.
The only real concern is that the window in the guest WC might be too small. But I don’t know how I could change that. Maybe it’s enough. No idea.
Tarnari28 May 2020 01:17
@Shiny86
Just build.
It won’t be perfect. It will cost more. It will be different.
But it will be your home.
Do it!
