ᐅ Floor plan of a single-family house with a basement
Created on: 30 Apr 2017 17:37
baumhaus815
Here are the ground floor and first floor plans.
2D floor plan showing living room, bedroom, kitchen, hallway, and staircase
First floor plan of a house with rooms 1-8, staircase and doors.
3 May 2017 23:16
baumhaus815 schrieb:
Do you mean that the dressing room access should not be parallel to the gable side, but instead positioned at a 90-degree angle to the bedroom door? We had thought about that too, but then when leaving the dressing room, wouldn’t you be walking straight toward a potentially open bedroom door (and possibly bump into it)?
Parallel to the gable (vertical on the plan), and yes: 90 degrees to the bedroom door.
Access only, no door — that way you can also see who is entering through the door. You still have other senses... 😉 Don’t overthink it and assume you’re living with a thousand strangers in a bunker.
However, I would prefer internal access to the bathroom, so if the chimney is in the way, then more changes would be necessary.
Regards, Yvonne
