ᐅ Floor Plan Design for a Single-Family Home of Approximately 170 m² on a Narrow 750 m² Plot
Created on: 16 Mar 2021 11:35
ReneWie
Plot size: 750 m² (8,072 sq ft), 18 x 42 m (59 x 138 ft)
Slope: no, flat
Floor area ratio (FAR): 0.25
Plot ratio: 0.5
Building envelope, building line and boundary: 3 m (10 ft) from all sides
Edge development:
Number of parking spaces: minimum 2
Number of floors: 2
Roof type: gable, hip 25-45°
Architectural style: modern
Orientation: no requirement
Maximum heights / limits: 10 m (33 ft) according to development plan
Other specifications
Requirements of the Homeowners
Style, roof type, building type: solid construction, modern, gable roof, single-family home
Basement, floors: no basement, 1.5 floors
Number of occupants, age: currently 2 (both 32)
Space requirements ground floor (GF), upper floor (UF): 90 + 80 m² (970 + 860 sq ft)
Office: family use or home office?: home office upstairs
Occasional overnight guests: rare
Open or closed layout: open
Conservative or modern construction: mix
Open kitchen, kitchen island: open kitchen, no island planned so far
Number of dining seats: minimum 6 seats
Fireplace: light masonry heater
Music / stereo wall: no
Garage, carport: planned, at the rear of the property
Utility garden, greenhouse: preferably a utility garden behind the house
Additional wishes / special features / daily routine, including reasons for choices or exclusions:
- Large open living/dining area with southern exposure.
- Large terrace at the front of the house, accessible from kitchen/dining area.
- Garage not in front of the house to preserve sunny space 🙂 — driveway located north beside the house instead.
- Minimum roof pitch on the upper floor.
- Possibility to reduce living room size later to create a bedroom (planned door in front of guest WC).
- TV area rather small, as we’re not typical couch potatoes :-D
- Office with dormer window.
Designer:
- Do-it-Yourself: based on a prefabricated house provider’s plan template
- House set back 10 m (33 ft) from the street, large living area due to frequent visits from a large family.
What do you dislike? Why?
- Possibly the kitchen is too small.
- Possibly insufficient storage space.
Price estimate from architect/planner: appointment pending
Personal budget limit for house including fittings: 350,000 (planned DIY for electrical, flooring, heating, plumbing)
Preferred heating technology: geothermal heat, possibly solar thermal support
If You Have to Give Up Something, which details/features
- can be foregone:
- direct access from living room to outside
- cannot be foregone:
- terrace access
Why has the design turned out as it is? e.g.
- Everything was placed on the ground floor with the option to create an additional room later by adding a wall in today’s living room (door in front of guest WC in living room).
- Large terrace at the front of the house is important and there is enough space.
Are there issues with the size of the utility room if washing machine, dryer, technical equipment, and storage space are included?
Is the guest WC with shower sufficiently large?
Do the room sizes appear reasonable?
House floor plan: kitchen, dining/living, utility room, hallway, bathroom, WC, and terrace.
Residential floor plan: master bedroom, children’s rooms, office, corridor, and bathroom on one level.
Site plan: green plot 370 with entrance and garage; surrounding parcels 369, 371, 372.
NKB2020
16 Mar 2021 15:27
ReneWie schrieb:
Then we still can’t get behind the house if the garage is located at the back 🙂. I think it might also be too tight for driving in.
There are also garages designed for drive-through access. Maybe that could be an alternative?
ReneWie
16 Mar 2021 15:28
What made you choose this basic layout?
Overall, the room layout works well.
Ground floor:
Large open-plan living and dining area, pantry well positioned, storage space in the hallway (cloakroom behind the front door), guest toilet with shower (for when older), easy option to add an extra room (in the living room, for later), relatively large utility room possible (no basement).
Upper floor:
Office possible (with dormer), walk-in closet for the parents, room sizes are acceptable (still need to calculate with the roof).
11ant16 Mar 2021 15:31
ReneWie schrieb:
Room sizes are fine (still need to be calculated with the roof)
Is it because you haven’t yet determined how increasing the house depth by half a meter (20 inches) affects the 1m (3 ft) and 2m (6 ft) lines?
ReneWie
16 Mar 2021 15:35
Because you haven’t yet determined how increasing the house depth by half a meter (20 inches) affects the 1m (3 ft) and 2m (6 ft) lines?
Correct, and because the example plan features a hip roof, similar to a townhouse.
We want a gable roof, so we still need to check the appropriate knee wall height.
11ant16 Mar 2021 15:46
ReneWie schrieb:
We want a gable roof, and we still need to determine the appropriate knee wall height.
Oh, that largely makes the sample floor plan unsuitable. How much knee wall height are you allowed?
icandoit
16 Mar 2021 16:12
Because you haven’t yet determined how increasing the building depth by half a meter affects the 1m and 2m lines?
There is flexibility here. Maximum height: 10 m (33 feet)
