ᐅ Floor plan: New construction on an existing bungalow basement, one-and-a-half stories
Created on: 19 Dec 2022 01:12
Mal Bauen
Hello to all forum members,
We are still relatively early in our building project and have many fundamental questions to clarify. Nevertheless, I would like to introduce the project here.
We recently became owners of a prefabricated bungalow from Streif Haus, built in 1987. It has a full concrete basement (by Betonkemmler).
Our plan is to demolish the bungalow down to the top edge of the basement and build a new house for our family (currently four, eventually five) on top. The existing basement (very solid construction) is to be integrated as a utility basement including a technical room. At the same time, the heating system will be modernized from oil heating to a heat pump.
Currently, we are in contact with both prefabricated house suppliers (Weberhaus, Danwood) and solid construction companies (Denkinger). The property is located in Baden-Württemberg (southern Baden).
Even though the floor plan is only a first draft, I would like to present it here for feedback (summary below).
In particular, I hope to get some thoughts on the following basic questions:
  • Has any forum member gained experience with building on an existing basement?
  • Is there generally a preferred construction method for our project? We are still undecided whether to go for a prefab timber frame house or a masonry (brick or block) solid construction.
  • So far, we have not discussed a double garage with the builders, but it will be needed. Where does it make more sense: northwest or southwest (directly next to the neighbor’s garage)?
  • To what extent can the project be treated as a renovation with partial demolition in terms of building regulations? Background: Are there any possibilities for funding (still) available?
  • What we want to achieve with the floor plan is short walking distances inside and around the house. Therefore, the main entrance was moved from the north side to the west side. However, since it is on the short side of the house, this results in more corridor space and longer routes inside (e.g., from the front door to the stairs to the upper floor). But as the saying goes, you have to accept some drawbacks — what is your opinion: front door facing north or west?
Here is the summary sheet (key points).
Many thanks in advance for your input, comments, and critiques. I will gladly report further developments here in the thread.
Size of the plot:
615m² (6620 sq ft)
Slope: North/South: <0.5m (1.6 ft) over 18m (59 ft), West-East: approx. 2m (6.6 ft) over 33m (108 ft) (see elevation profile)
Site coverage ratio: No development plan (Section 34 of German Building Code). The immediate neighborhood contains some generously built plots. We do not want to change the building footprint of the existing house but want to add a double garage (not currently present).
Floor area ratio: No development plan (Section 34 of German Building Code)
Building envelope, building line and boundary: No development plan (Section 34 of German Building Code). Property boundaries and existing building shown in aerial photo attached
Edge development: None
Number of parking spaces: None
Number of floors: 1.5 stories
Roof type: Gable roof
Architectural style: Modern detached family house
Orientation: see aerial photo. Entrance (currently): north
Maximum height/limits: No development plan
Immediate neighbors: Northern neighbor: 2 stories with flat roof. Southern: 1.5 stories with hipped roof. Western: 1.5 stories with gable roof.
Style, roof form, building type:
We want to transform the existing bungalow into a classic 1.5-story detached house with a gable roof and possibly shed dormers.
Basement, floors: Utility basement (existing, concrete basement), ground floor (living), upper floor (sleeping)
Number of persons, ages: Our family currently has four members (ages: 32, 30, 2, 0), with another child planned
Space requirements on ground and upper floor:
Ground floor: living room, kitchen (possibly with pantry), room for home office or guest room, guest WC with shower, cloakroom
Upper floor: master bedroom, 3 children’s bedrooms, bathroom
Office: family use or home office: Home office (100% for me)
Overnight guests per year: Few, less than 5 guests/nights
Open or closed architecture: Rather closed. Ability to separate kitchen and living room would be desirable.
Conservative or modern design: Modern
Open kitchen, kitchen island: Kitchen island not mandatory. Partly open kitchen: separation from living room would be good.
Number of dining seats: 5-8
Fireplace: Only if budget allows, not mandatory
Music/ stereo wall: No
Balcony, roof terrace: No
Garage, carport: Double garage
Further wishes/special features/daily routine, including reasons for preferences or exclusions: The technical room should be located in the existing basement (e.g., in the former oil heating room). A sensible circulation concept is very important: front door/upper floor stairs/basement stairs. Ideally, short distances between garage and house as well as good accessibility of rooms within the house.
Designed by:
Initial draft from the prefab house supplier after first meeting
What do you especially like? Why?: (Almost) all room requests fulfilled. Good accessibility of upper floor rooms via centrally located landing. Short distances from garage to house thanks to new front door position (west instead of north). Spacious cloakroom area. Living room oriented south/east with a nice view.
What do you not like? Why?: The draft was created after an initial discussion of the project. Some ideas and preferences developed or changed later on by us:
- Existing concrete stairs in the basement will not be used, causing extra costs for upgrading the basement (new stairs, new room layout).
- (Small) pantry for food/storage on the ground floor would be great
- Better separation of kitchen and living room is desirable
Price estimate according to architect/planner: 520,000 € (approx. $560,000), turnkey (including 10kWp photovoltaic system with 10kW storage, fresh air heating with air-to-air heat pump), excluding demolition of existing bungalow, double garage, incidental building costs
Personal price limit for house including fittings: 700,000 € (rough estimate: demolition down to top of basement: 30,000 €, house: 530,000 €, incidental costs including basement statics: 50,000 €, double garage: 30,000 €, kitchen/furniture: 40,000 €, landscaping: 20,000 €)
Preferred heating technology: Heat pump with underfloor heating. If budget allows: ground-source heat pump with deep geothermal drilling. The prefab house supplier prefers fresh air heating.
If you had to give up something, which details or add-ons could you do without: Fireplace, new basement stairs
What can you absolutely not do without: Home office
Why is the design like it is now?
Individualized draft by the prefab supplier adapted to the existing basement footprint after discussing our rough (space) requirements.
Architectural drawing of a house with north, east, west, and south views and trees.
Floor plan of house: living and dining area, kitchen, bedroom, guest room, bathroom, hallway, terrace.
Floor plan of house: basement with storage, laundry, equipment, hallway, heating.
Cross-section of residential building with roof structure, ground floor, basement, stairs, and foundations.
Floor plan of house: bathroom on left, master bedroom bottom left, rooms 1–3 and landing in the center.
Floor plan of house: kitchen, dining/living room, foyer, cloakroom, shower bath, office/guest.
Floor plan basement: rooms basement 1, basement 3, installation, hallway, stairs.
Architectural plan: two section drawings (Section 1 and 2) of a building with orange lines and dimensions.
Aerial photo: plot marked with blue rectangle for house; entrance, dimensions 18m × 33m, 615m².
11ant19 Dec 2022 16:25
Mal Bauen schrieb:
35 years is not really old for a prefab house either, but especially the insulation is outdated (e.g., exterior walls 18cm thick (7 inches)). Since we also want to adjust the heating system (underfloor heating) and the floor plan according to our needs, we would have to completely gut the house.
I understand that, I have been involved in owner-build planning for four decades. Upgrading the insulation system (bringing the ETICS/external thermal insulation composite system up to current standards, possibly adding a service cavity) is so far off from the manufacturer’s current industrial product that at least a conversation with a local timber construction contractor (carpenter) is worth considering as an alternative. Don’t underestimate the insulation back then; the values were several orders of magnitude better than those of masonry houses at the time. In the mid-80s, we’re talking about mostly 30 cm (12 inches) hollow blocks or 36.5 cm (14 inches) brick, which were clearly outperformed by 16 cm (6 inches) wood frame panels with what today would be called ETICS.
Myrna_Loy
19 Dec 2022 16:35
Demolishing and disposing of a house just because of underfloor heating, that's exactly my kind of humor 😉
The great thing about timber frame houses is that they are ideal for remodeling, extending, and renovating. With some luck, you might even be able to benefit from new subsidies for renovating older buildings.
Underfloor heating pipes can, for example, also be retrofitted by milling into the existing floor.
WilderSueden
19 Dec 2022 17:03
Replacing a Streif house from 1987 with a new Danwood model would not result in any qualitative improvement – that would mean redesigning the floor plan for a significant amount of money, which apparently is not a priority for you?
I also find it interesting that Weberhaus and Danwood, two prefabricated home builders, are at opposite ends of the price spectrum on your list. It seems the plan hasn’t been fully thought through yet. I’d like to mention that my future neighbor, just two houses down, has been waiting for his Danwood house for about 14 months, with a targeted installation date at the end of February. Although the backlog has eased somewhat last year, remodeling is certainly faster. For underfloor heating, ceiling or wall heating systems are also options.
Mal Bauen schrieb:
It didn’t seem sensible to us to save, say, €50,000 (random number), only to end up planning, building, and living for decades with too many compromises.
Have you calculated the costs of renovation? Just the €30,000 (about $33,000) demolition alone would cover a photovoltaic system with battery storage. With a budget of €100,000 to €150,000 (about $110,000 to $165,000), you should get quite far, potentially saving an order of magnitude more overall.
11ant19 Dec 2022 17:27
WilderSueden schrieb:
I also find it interesting that Weberhaus and Danwood, two prefab builders, are listed at opposite ends of the price spectrum. The plan doesn’t seem fully thought out yet.
I have seen one and I think the same about the other, but I wouldn’t link them so "causally."
At this point, I also want to mention that my future neighbor, two houses down, has been waiting for his Danwood house for about 14 months, with a planned installation date at the end of February.
February always comes around, maybe in 2023 even with the usual carnival (?)
WilderSueden
19 Dec 2022 17:38
Yes, it’s about February 23, although it might also be March. By the way, in the south it’s not called Carnival but Fasnet (standard German: Fasnacht) 😉.
The exact date is not important; I just wanted to point out to the original poster how long it can take for a prefabricated house to reach the shell stage. And then there is still a lot of work to be done inside.
19 Dec 2022 20:57
Myrna_Loy schrieb:
The great thing about timber frame houses is that they are very easy to modify, extend, or renovate.
I agree. You can actually "quickly" and easily improve the insulation and install underfloor heating. The technology can also be replaced without much hassle.
Mal Bauen schrieb:
It didn’t seem practical to us, for example, to save "only" $50,000 (number pulled out of thin air),
But your concern is also about subsidies. That would be eligible for support, while new builds usually are not, as you know. Additionally, homeowners should consider how to save on materials nowadays, and the same applies to waste disposal. The renovation subsidies exactly reflect that.
Myrna_Loy schrieb:
With some luck, you might even benefit from the new grants for renovating older buildings.
Nowadays, prefabricated houses can have a completely different appearance. I would suggest discussing this with an architect, or even with the team at Streif Haus. A house from 1987 is still quite young, unless it’s heavily contaminated with formaldehyde or similar. Think it over again.
