ᐅ Floor plan for a single-family house
Created on: 1 Nov 2013 12:46
Jimmylein
We are currently at the stage where we plan to build a house within the next few years. Since a new residential development is being announced in a location we are interested in, we have already started thinking about the topic of building. Because the plot of land influences the house design and we do not have it yet, our approach was to consider the house layout first. The floor plan presented here would fit well on one of the approximately 3 to 4 lots available in the new development.
The house should have two full stories and a basement.
I would appreciate any comments or suggestions you might have.
Jimmylein
2D floor plan of a house with several rooms and an orange highlighted area
2D floor plan of a house with living room, hallway, kitchen, and bathroom
2D floor plan with yellow-brown rooms and mini architectural designs
Jimmylein
3 Nov 2013 13:40
Okay. The small walls could also be removed. Possibly the niche behind the front door as well. The garage is preset on all the plots on this side since the driveway location is fixed. It might be possible to make it shorter or move it closer to the street.
The staircase is exactly the smallest one available in terms of size. So it should fit. I understand that the children’s rooms should be the same size. I’ll start working on something completely new again.
Thanks for the suggestions so far.
3 Nov 2013 17:13
Jimmylein schrieb:
... The garage is predetermined on all the plots on this side because the driveway location is fixed.
One thing does not mean the other. If you are not so rigid about strictly following the requirements but still want to make the most of your plot (and not just copy others as examples), then an architect needs to handle it.
For example: in our case, the requirement is that the driveway must be on the left side (for us, that means the east side from the north). But that doesn’t mean I can’t position the garage as a privacy shield on the right side. Luckily, our cars can still make a turn—even on a plot 🙂 Within the building envelope, you have quite a bit of flexibility 😉
f-pNo4 Nov 2013 09:57
Why are there windows to the left and right of the bed?
Jimmylein schrieb:
Regarding the windows in the bedroom:
- A window directly above the bed is not desired, but two windows in the room are okay.
Hello Jimmylein,
I would like to ask again in general: What is the reason for placing these windows behind the bed (or to its left and right)? You already have a large double-glass door facing south. This should provide the room with plenty of natural light.
Another question: What is the purpose of the area between the guest toilet and the pantry, or between the children's room and the bathroom? Is it supposed to be the utility room—in which case you would need a door? Or is it just a shaft for chimneys—that area wouldn’t need a window then. I can't quite identify this space at the moment.
In the living room, the sofa completely blocks one glass door—okay, it’s not mandatory to arrange it that way. But if you do, why invest in a large double-glass door only to have it blocked?
As a general rule, it might be best to follow this principle: place many windows on the south and east sides, and fewer windows on the north and west sides (the more exposed weather sides). Check whether windows such as the one in the bathroom above the toilet or those above the beds in the children’s rooms are really necessary. With the other large windows in each room, you already have sufficient light—and these windows also reduce usable wall space for furniture.
That’s all for now.
f-pNo
Musketier4 Nov 2013 18:49
f-pNo schrieb:
One more question: What exactly is the area between the guest bathroom and pantry, as well as between the children's room and bathroom? Is this supposed to be the utility room – in that case, you would need a door? Or is it just a space where chimney flues run – then this area wouldn't need a window? I can't currently identify the purpose of this area.
This is most likely a staircase or a stair landing.
4 Nov 2013 21:51
f-pNo schrieb:
In general, the following principle might be useful: Many windows on the south and east sides, fewer window areas on the north and west sides (weather-exposed sides).
However, many see this differently: West side = window side, because in the late afternoon when the sun comes from the west, it can be enjoyed, unlike on the east side 🙂
Ingo Kommen
10 Nov 2013 14:18
The garage is better designed than the house :-)
