ᐅ Floor Plan for a Multi-Generational Home on a Challenging Plot of Land
Created on: 7 Aug 2021 17:38
MidnightBlack
I am currently considering building a multigenerational house together with my parents. We have a plot of land available (about 700m² (8,350 sq ft)) in a location we really like, but the shape of the plot is unusual and presents some challenges for the initial planning.
I hope to get some ideas from you that might lead me in completely different directions. I keep coming back to the same solution (I have included a very rough draft below): From the street view, a single-family house with a garage to the right, and at the back an accessory dwelling unit (ADU) as an extension.
We’ve already had several discussions with my parents and know what kind of solution we envision. Fortunately, there is no pressure or obligation that an additional unit must definitely be included. However, we can well imagine it if these conditions are met:
  • Separate entrances on different sides of the building
  • The terraces of the single-family house and the ADU should not be directly adjacent; preferably separated or around the corner
  • Windows of main living spaces (living room, kitchen, etc.) should not face into each other’s garden
This should not be understood as us wanting no contact or view of each other. We already live together under one roof without any issues. But we would like to implement the points above. Also to be able to rent out the ADU to “outsiders” in a few decades, if needed.
The rough draft basically shows a classic single-family house with a detached garage. The kitchen and living room face south/west towards the garden. Behind the garage is an extension (single story only, possibly flat roof) that partially overlaps with the main house. The living/kitchen area is in the northern part, with the possibility to place a terrace in the designated cutout (to keep within the 3m (10 ft) limit). The bedroom is located by the wall next to the garage; the bathroom roughly beneath the “9.5m (31 ft)” dimension.
What I like about this draft:
  • Structurally and physically separated; from the street, the extension is barely visible; it still looks like a “normal” single-family house
  • Separate outdoor areas in the garden
  • The possibility to drive past the single-family house on the left into the garden (especially useful with a trailer for garden work, etc.)
What I’m not so happy with:
  • I struggle with the idea of not allowing my parents proper south/west-facing windows in this design
  • The described bathroom with an existing window would look directly into our garden
I look forward to more ideas, especially completely different approaches. As I said, I fear I’m a bit “blind” at this point. I hope this “draft stage” is okay—I haven’t dared to start interior planning until the basic structure is more satisfactory.
Site plan of a house with SFH/ADU, garage, dimensions, and north arrow.
hampshire
8 Aug 2021 18:17
MidnightBlack schrieb:
Isn’t the sentence a bit incomplete? Do you notice anything / Do you like something or is this meant as a suggestion? ;-)
“one,” My first thought is a staggered asymmetrical semi-detached house. So, a suggestion.
8 Aug 2021 18:34
Basically, no parking space is required for the secondary apartment.
Who says that?
The building regulations in North Rhine-Westphalia (NRW) state that one parking space is required per housing unit.
I believe an architect will definitely be essential at the planning stage here.
MidnightBlack
8 Aug 2021 19:35
Who says?
The building regulations in NRW specify that one parking space is required per residential unit.
Yes, that’s correct. In my list, I come up with 3 parking spaces. What I wanted to express is: the separate apartment does not require an additional parking space. Whether all three parking spaces are used by one residential unit or not shouldn’t matter, as long as they can be accessed independently.
I assume an architect will be indispensable during the planning phase here.
Definitely. For my planning, the main goal is to get a sense of whether it is possible on the plot and what floor plan options there are for the residential unit. Based on that, a decision will be made later about whether to build the separate apartment at all. If the desired parameters cannot be achieved satisfactorily, it doesn’t make sense to build a separate apartment.
Certainly, an architect is helpful if you ultimately decide to go ahead with the single-family house alone, but then that’s money well spent.
K1300S8 Aug 2021 19:43
It would be even more unfortunate to start with incorrect assumptions and later realize that the project cannot be executed as planned. Consult an architect or a good construction manager. For a relatively low four-figure amount, they can provide you with a competent and feasible plan, which you will need anyway. Anything else won’t help you, not even the opinions of the members involved here.
11ant8 Aug 2021 21:37
The statement is clear. Do you generally decide against creating your own design, or do you see no other option here?
The headline contains a key term ("challenging plot") that strongly suggests the advisability of hiring an architect rather than settling for a draftsperson. But just as a draftsperson benefits from a client’s existing design as a starting point, the anchoring effect of such priming can be detrimental when working with an architect on a design.
I currently don’t have the site development plan yet.
The absence of this essential basis is exactly the pitfall of planning without all the necessary information. So get that as soon as possible.
