ᐅ Preliminary floor plan design for a 220 m² single-family house
Created on: 20 Jun 2017 22:41
R.Hotzenplotz
Hello!
We have already gone through several plans with our architect and I think we are almost there, about to start the detailed planning phase. Before that, I’m looking forward to getting feedback from other users.
Development plan/restrictions: §34 – two full stories
Plot size: 1,085m² (1,1679 yd²)
Basement, floors – 2 full stories plus partial basement
Number of people, ages – 3 people (37, 34, 1, second child planned)
Space requirements on ground floor and upper floor – the requirement was that bedrooms and the study should be about 17m² (183 ft²) each; the entire house should be approximately 220m² (2,368 ft²)
Office: family use
Guests per year: 1
Open or closed architecture: closed
Traditional or modern design: modern
Open kitchen, kitchen island – no open kitchen, but yes to a kitchen island
Number of dining seats – 6
Fireplace – yes
Music/stereo wall – TV wall
Balcony, roof terrace – balcony
Garage, carport – large garage
Additional wishes/special features/daily routines, preferably with reasons why certain things should or should not be included – everyone should be able to sleep as undisturbed as possible in their bedrooms, even if other family members are awake. The husband is sometimes up as early as 4 a.m. Otherwise, watching TV in the evening should be possible without disturbing those sleeping upstairs.
Who created the design:
- Architect (freelancer for a general contractor)
What do you like most? Why?
The upper floor with well-sized rooms and the location of the rooms exactly where they should be (only the washroom area we would still like to move to the outer right corner so that you don’t have to pass it every time you use the toilet). On the ground floor, the access through an airlock, the kitchen, and the dining area with the study next to it are especially liked.
Also appreciated is that after adjustments, the study now faces the garden instead of the street.
What don’t you like? Why?
We originally wanted the distance from wall to wall where the sofa and TV stand is to be about 6.40m (21 ft) (large screen & surround system), but so far only 5.69m (19 ft) has been realized.
Laundry room as described.
Kitchen larger in square meters than needed; the approx. 3m² (32 ft²) could theoretically be used well in the living area.
720,000 euros (including construction incidentals)
Personal price limit for the house, including equipment:
800,000 euros
Preferred heating technology:
Gas
If you have to give up on something, which details/features can you do without?
- Can do without:
Technical systems like controlled residential ventilation
- Cannot do without:
Space (except for the kitchen)
Why is the design the way it is now? For example:
Is this a standard design from the planner?
The architect has largely implemented our wishes; the only issue is the living room situation.
Patient, quick to implement, has already gotten to know us well.
No negative points.
Do you notice any other points that might not fit or that we should consider, which we might have overlooked?
In the basement, the room currently labeled as home cinema might possibly be used as one medium- to long-term. For the foreseeable future, it will be a storage room.
R.Hotzenplotz
21 Aug 2017 12:46
kaho674 schrieb:
..the stair side does not change because of that and could still be clad with glass.
There would have to be a glass surface removed on the right side along the entire width of the stairs where the staircase descent would go and where there used to be railing cladding. Or not?
kaho67421 Aug 2017 12:52
No, that would be the space you need just to reach the staircase. So the starting point, which should not be less than 1 meter (3.3 feet) here.
R.Hotzenplotz
21 Aug 2017 12:53
kaho674 schrieb:
No, that would be the area you actually need just to access the stairs. So the stair landing, which should not be less than 1m (3.3 ft) here.
Then I obviously don’t understand what was meant. Never mind. Let the architect figure it out.
21 Aug 2017 13:00
... the access to the basement stairs would be from the front, through the hallway... therefore, the ground level on the right side of the ground floor would be slightly shorter than the stairs leading to the upper floor, because that is where the basement stairs start, according to kaho.
But honestly: I wouldn’t find that aesthetically disturbing, and access from the front would be much more practical... otherwise, I wouldn’t have asked what’s so bad about it.
Best regards, Yvonne
R.Hotzenplotz
21 Aug 2017 13:02
... the basement staircase access would be at the front, from the hallway... therefore, the terrain on the right side of the ground floor would be slightly shorter than the staircase to the upper floor, because that's where the basement stairs start, according to kaho.
That’s how I also described it last time. But kaho’s last post then confused me.
kaho67421 Aug 2017 14:25
Sorry for the confusion. I just wanted to clarify that there may be little or no change to the possible glass wall of the staircase.
