ᐅ Floor plan design for a two-family house on a hillside
Created on: 16 May 2017 14:23
sichtbeton82
I would appreciate your feedback on the floor plans.
Development Plan / Restrictions:
· Plot size: 1,200 m² (18 m (59 inches) wide)
· Slope: south-facing hill, street to the north
· Site coverage ratio: 0.3
· Floor area ratio: 0.6
· Building envelope, building line, and boundary: see "enlarged building envelope" 12 x 14 m (39 x 46 feet)
· Edge development: garages
· Number of parking spaces: 3 required according to building authority
· Construction type: open building layout
· Building setback: 3 m (10 feet)
· Roof type: pitched roofs 15-30°, hipped roofs to be avoided, see regulations
· Orientation: ridge direction of the buildings parallel to each other
· Exterior design: see section 6 of the regulations
Homeowners’ Requirements
Preliminary: The homeowners (born 1982 male, 1988 female, and two children born 2014 female, 2016 male) want to live on two floors (basement and ground floor). A third children’s bedroom should also be included. The third floor (attic) should be accessible barrier-free.
· Style: Bauhaus (optionally exposed concrete)
· Roof design: large south-facing side (for solar panels, photovoltaics)
· Building type: two-family house
· Basement and floors: basement, ground floor, attic
· Number of occupants and ages as above: (2 + 3 in basement and ground floor, 2 + 1 in attic)
o Space requirements attic: 2 bedrooms, 1 flexible floor plan bathroom, open living/dining/kitchen area, utility room
o Space requirements ground floor: 1 master bedroom, walk-in closet, master bathroom, large open living/dining/kitchen area, wardrobe, storage room
o Space requirements basement: 3 children’s bedrooms, children’s bathroom, optional play corridor, boiler room, cellar, utility room
· Open or closed architecture: open
· Conservative or modern construction: modern
· Kitchen: open kitchen with island (at least on ground floor)
· Balcony, roof terrace: likely sensible on all three floors considering exposed concrete
· Parking spaces: carports if possible, which can later be converted into garages (initial cost saving)
· Heating/thermal technology: air-to-water heat pump (underfloor heating), optional photovoltaics
· Windows: large window areas on the south side, optionally wide, low windows above the kitchen worktop on the ground floor
· Energy efficiency: KfW 55 standard
· High sound insulation (especially for the ceiling of the attic, separate residential unit)
East view: sketch with stacked rectangles, diagonal line and hatched triangle.
Elongated plot marked in yellow on a site plan with parcel numbers.
Ground floor plan: living/cooking area, master bedroom with walk-in closet, bathroom, WC, hallway, terrace.
Hand-drawn basement floor plan with hallway, cellar room, bathroom, and three children’s bedrooms.
sichtbeton82
21 Nov 2017 13:29
I used the wrong term there. It is not a skylight. It should be a fixed window that starts at about 2.2m (7 feet 3 inches) room height and extends up to just below the ceiling (2.7m / 8 feet 10 inches).
21 Nov 2017 13:40
sichtbeton82 schrieb:
I used the wrong term there. It’s not a skylight. It should be a fixed window starting at about 2.2m (7.2 feet) room height and extending up to just below the ceiling (2.7m / 8.9 feet).
That is also called a transom window [emoji2]
A transom window or clerestory is not necessarily limited to exterior walls.
11ant21 Nov 2017 14:05
even though we didn’t accept everything.
That’s nicely put
kaho674 schrieb:
One can only hope that pushing it back a bit will somewhat reduce the issue.
Sort of. In principle yes—but as soon as you look at it from a steep enough angle to notice the depth offset, you also see how it interacts with one of the completely mismatched sides :-(
chand1986 schrieb:
Roughly, 42 degrees over 13m (43 feet) is just under 12m (39 feet) of slope. Is that correct??
Ninety percent or 11.7 meters (38 feet). Let’s hope 42° is meant, that would be about 23% or 3 meters (10 feet) ...
chand1986
21 Nov 2017 15:51
Ninety percent or eleven meters seventy. Hopefully, 42° is meant, which would be just under 23% or three meters ...
Huh? I might be mistaken, but if I tilt something 45° from the horizontal toward vertical, the resulting slope rises or falls exactly 1 meter over a 1 meter horizontal distance. That makes 100% slope for me. So 42° is therefore over 90%, and I sure hope the property doesn’t look like that?
A 23% gradient would be about 10.5°. With that, at least I get 3 meters.
Where is my error in thinking?
kaho67421 Nov 2017 17:21
I used the wrong term there. It’s not a clerestory window. It should be a fixed window starting at about 2.2m (7.2 ft) room height and extending up to just below the ceiling (2.7m / 8.9 ft).
No, my mistake. I would actually extend that clerestory all the way down. It brings a lot more light and also creates interest while showering. Especially when guests come over.
11ant21 Nov 2017 17:46
chand1986 schrieb:
Where is my mistake in thinking?
Not yours, mine.
Oh crap... the phone rang while I was typing on the calculator. Multitasking mess.
Let's hope 42° is meant, that would be just under 23% or three meters (10 feet)...
It should have said:
Let's hope 42% is meant, that would be just under 23° or five and a half meters (18 feet).
