I would appreciate your feedback on the floor plans.
Development Plan / Restrictions:
· Plot size: 1,200 m² (18 m (59 inches) wide)
· Slope: south-facing hill, street to the north
· Site coverage ratio: 0.3
· Floor area ratio: 0.6
· Building envelope, building line, and boundary: see "enlarged building envelope" 12 x 14 m (39 x 46 feet)
· Edge development: garages
· Number of parking spaces: 3 required according to building authority
· Construction type: open building layout
· Building setback: 3 m (10 feet)
· Roof type: pitched roofs 15-30°, hipped roofs to be avoided, see regulations
· Orientation: ridge direction of the buildings parallel to each other
· Exterior design: see section 6 of the regulations
Homeowners’ Requirements
Preliminary: The homeowners (born 1982 male, 1988 female, and two children born 2014 female, 2016 male) want to live on two floors (basement and ground floor). A third children’s bedroom should also be included. The third floor (attic) should be accessible barrier-free.
· Style: Bauhaus (optionally exposed concrete)
· Roof design: large south-facing side (for solar panels, photovoltaics)
· Building type: two-family house
· Basement and floors: basement, ground floor, attic
· Number of occupants and ages as above: (2 + 3 in basement and ground floor, 2 + 1 in attic)
o Space requirements attic: 2 bedrooms, 1 flexible floor plan bathroom, open living/dining/kitchen area, utility room
o Space requirements ground floor: 1 master bedroom, walk-in closet, master bathroom, large open living/dining/kitchen area, wardrobe, storage room
o Space requirements basement: 3 children’s bedrooms, children’s bathroom, optional play corridor, boiler room, cellar, utility room
· Open or closed architecture: open
· Conservative or modern construction: modern
· Kitchen: open kitchen with island (at least on ground floor)
· Balcony, roof terrace: likely sensible on all three floors considering exposed concrete
· Parking spaces: carports if possible, which can later be converted into garages (initial cost saving)
· Heating/thermal technology: air-to-water heat pump (underfloor heating), optional photovoltaics
· Windows: large window areas on the south side, optionally wide, low windows above the kitchen worktop on the ground floor
· Energy efficiency: KfW 55 standard
· High sound insulation (especially for the ceiling of the attic, separate residential unit)
sichtbeton82 schrieb:
I hope you will continue to support us with feedback during the next phase, even though we haven't accepted everything. Bedroom: The 60 cm (24 inches) planned on the left side for the wardrobe already causes issues in the shell construction, as the mason will place a 60 cm (24 inches) wall section up to the door...
Then you still have to consider the door frame, baseboard, and enough clearance to the wardrobe back panel (on the exterior wall!!!)
From a design perspective, you quickly need 70 to 75 cm (28 to 30 inches) rough space if you want a narrow 60 cm (24 inches) wardrobe (which often tends to be 70 cm (28 inches) deep). And given the length along the exterior wall in a new build, a 10 cm (4 inches) gap is better than 5 cm (2 inches) for ventilation; otherwise, there is a risk of mold on the laminated back panel...
From the outside, the window view also seems too plain to me. I would choose corner windows with staggered offsets across the plane, such as right - left - right. Of course, this complicates things inside again.
sichtbeton8221 Nov 2017 11:55haydee schrieb:
How much elevation difference do you have?
I think our structural engineer and the geologist he consulted would have a heart attack.
We have 13 meters (43 feet) and a 42-degree slope.42 degrees? That’s quite steep. The property’s highest point on the west boundary is at 383.34 m (1,258.6 ft) and the lowest at 364.60 m (1,196.2 ft). That’s a difference of 18.74 m (61.5 ft). The length of the west boundary is 72.66 m (238.5 ft). This results in a slope of about 14.5° or 25.8%.
sichtbeton8221 Nov 2017 11:58 What seems spectacular to me is the bathroom wall by the shower. Is it made of glass due to lack of light? I think that’s really cool.Do you mean the wall marked "white" in the bathroom on the ground floor? The wall between the bathroom and the hallway will have a skylight / transom window, and the one inside the bathroom will not extend all the way to the ceiling.
Are you referring to the wall marked "white" in the ground floor bathroom? The one from the bathroom to the hallway will have a transom window, the one inside the bathroom will not be built up to the ceiling. Yes, I meant the one from the bathroom to the hallway. I thought it would have a frosted glass insert. That would be great.
On the other hand, I don’t quite understand how a transom window in a wall is supposed to look.
chand198621 Nov 2017 12:43Uhm...
At 45 degrees, you have a 1 meter (3.3 feet) rise over 1 meter (3.3 feet) of distance. Roughly speaking, 42 degrees over 13 meters (43 feet) is just under 12 meters (39 feet) of slope.
Is that correct??
Is that correct??
