ᐅ Floor plan design for a hillside house with 5 children's bedrooms
Created on: 17 Jun 2017 12:31
Arifas
Dear fellow contributors,
I’m sharing our first attempt at the floor plan. Unfortunately, I can’t fill out the list because copying it over on my phone doesn’t work properly, sorry.
Key data:
5 children between 0 and 11 years old
2 adults in their mid-thirties
Plot of about 900 sqm (9700 sq ft), facing north
Building window edge on the street side: 17.35 m (57 ft)
Sloped site; within the building window, the ground rises about 2 m (7 ft) over 10 m (33 ft) from front to back
We want 5 small children’s bedrooms, a slightly larger office for working from home, a master bedroom, three showers, three toilets, a bathtub, and access to the garden through the living room on the upper floor. One wall in the children’s rooms should be removable later.
The attic is walkable.
We are allowed to build 2 full stories, with a ridge height of about 12 m (39 ft) and an eave height of 11.6 m (38 ft).
We would prefer a hip roof.
The current drawing is 9.5 by 11 m (31 by 36 ft), but we would like to have around 195 to 205 sqm (2100 to 2200 sq ft) of living space later; garage or storage will be added.
The back wall of the house is embedded up to about 2 m (7 ft) into the slope.
I will try to attach a rough overview of the plot.
Key data:
Here (Baden-Württemberg, district RV), the rules are the same regardless of whether it’s a dead-end street or not. A 5-meter (16 feet) clearance in front of the garage is required. Garages with electric doors were approved afterward to speed up access. However, this doesn’t really help, as drivers still often park halfway on the street or the sidewalk (the garages are frequently cluttered and not usable). Since I no longer have to push a stroller around, I don’t mind, but it does seem practical for most residential areas.
toxicmolotof28 Jun 2017 12:50Arifas schrieb:
Yes, that is a lot. But a garage plus driveways already add up to 2-3 meters (6.5-10 feet) along the property length, 2 meters (6.5 feet) in front of the house, and a 10-meter (33 feet) driveway on the other side.
No, not a federal road. A dead-end street in a very quiet part of NBG. However, building authorities usually will not approve three parking spaces lined up one behind the other. Two spaces that block each other are generally the limit, unless you play Tetris every time you want to access the car in the garage?
In the 3m (10 feet) side building setback, one can fit on each side (or two in a row behind each other), provided that nothing is lost to slope cutbacks.
Arifas schrieb:
According to the neighbor, if the driveway is long enough, you can have two parking spaces one behind the other. Yes, at least for the same dwelling unit. In this case, it means 15 m (50 feet): two parking spaces plus 5 m (16 feet) distance from the street. One of the two spaces will definitely be located next to the house, if not both.
