We are about to renovate a semi-detached house built in 1984. We are considering changing the layout on the ground floor. The following changes are planned:
Option 1: The kitchen remains unchanged; the advantage here is that the dining area is integrated into the kitchen.
Option 2: The kitchen moves into the small room; the disadvantage is that the dining table will then have to be placed in the living room.
Now for our big dilemma: at the back of the property, the previous owner built a storage room. Both exterior walls lie on the neighboring property and are constructed from Ytong blocks, with a building height of 2m (6.5 ft). There are two considerations here:
- The wall between the living room and the entrance area will be removed, making the living room larger and integrating the staircase into the living room.
- The existing conservatory is quite old and will be converted into a terrace (the garden is very small, so this will make the garden appear larger).
- Remove the storage room (the roof is leaking anyway) and convert the area into a small garden or courtyard, which would bring more light into the office and kitchen.
- Keep the storage room, enlarge the light well (the existing entrance area will be connected to the light well), add a double glass door to the light well, thereby increasing the light in the kitchen.
Schorsch_baut schrieb:
Would it be possible to build an extension for the kitchen instead of a conservatory?Theoretically yes, but the garden will become very small; otherwise, it’s a good idea. Thank you!K a t j a schrieb:
Before removing any load-bearing walls, it is important to know what is above them. Pipes and electrical wiring are likely integrated somewhere as well. Are there any plans available?The load-bearing wall will of course not be removed without consultation with the architect,
