ᐅ Floor Plan and Site Placement for a 135 sqm Single-Family House without a Basement
Created on: 29 Aug 2024 14:57
Papo8801
I am an active reader and have already gathered many ideas and opinions from this forum.
We are currently planning a single-family house on a plot of land, and I would like to get your feedback on the house placement as well as the floor plan.
Plot size 652 sqm (7,015 sq ft)
Slope: no
Site coverage ratio 0.4
Floor area ratio 0.8
Building zone, building line and boundary 3 m (10 ft)
Edge development limited to garages and carports only
Number of parking spaces 2
Maximum number of floors 2
Roof pitch 0–48 degrees
Architectural style single-family house
Orientation
Maximum height restrictions 6 m (20 ft) wall height, 9 m (30 ft) total height
Other requirements rainwater cistern
Homeowners’ Requirements
Style, roof type, building type gable or hipped roof
Basement, floors 1.5–2
Number of occupants, ages 2 adults and potentially 2 children
Office: family use or home office? Both
Guest bedrooms per year
Open or closed layout open
Traditional or modern construction open
Open kitchen, kitchen island open kitchen
Number of dining seats 1
Fireplace no
Music/sound wall no
Balcony, roof terrace no
Garage, carport yes
Utility garden, greenhouse possible
Other wishes / special features / daily routine, also reasons why certain things are or aren’t desired
Who created the design:
- Planner from a construction company / adapted production house design
What do you particularly like? Why? Large utility room with separate door (mudroom), large pantry
What do you dislike? Why?
Estimated price according to architect/planner: 400,000
Personal price limit for the house, including fittings: 400,000
Preferred heating system: air heat pump
If you had to give up on certain features or extensions
- Could do without: pantry, separate door utility room
- Cannot do without: guest WC with shower
Why is the design like it is? Example:
Standard design from planner adapted for a large utility room
So, it is a standard design customized to our wishes.
We have a dog and want to have two children. The house should suit this and not be too large. We can work from home, and if having children doesn’t work out, the office rooms will be used or only one office. If children do come, working in the small nook upstairs is planned.
Alternatively, a garden house may be built for occasional home office use. Otherwise, I commute to work.
I look forward to your opinions and possible improvement suggestions.
It is plot no. 9 (corner)
Grundrissplan eines Hauses mit Garage, Garten und Zufahrt.
Lageplan eines Baugrundstücks mit roten Gebäuden, Grünflächen, gelber Straße und Maßen ca. 652 m²
Grundriss eines Wohnbereichs mit Essecke, Küche, Speise, HWR, WC, Treppe und Pflanze.
Grundriss eines Wohnungsplans: Bad, Flur, Elternzimmer, zwei Kinderzimmer, Treppenhaus.
Ansicht von hinten: zweistöckiges Haus mit großem gestreiftem Dach, blauen Fenstern und Auto links.
Ansicht von links: Hausfront mit Giebeldach, blaue Fenster und Türen, Hund am Eingang.
Skizzenhaus mit steilem Dach, zwei blaue Fenster, Tür, Baum rechts, Person mit Kind links
Vorderansicht eines modernen Hauses mit langem Metall-Dach und blauen Glastüren.
11ant29 Aug 2024 17:55
Papo8801 schrieb:
Okay, the company is called Dennert Massivhaus. They offer modular houses built with solid concrete construction.
There are even more models available now on the website.
The floor plans are relatively fixed because the module with the service wall must always be in this position, with the guest toilet located behind it (according to the advisor); otherwise, the walls are more or less adjustable.
Oh, look, have they finally improved the lack of options compared to the (previously known four) Icons? – then I’ll have to check it out again sometime.
Papo8801 schrieb:
The upper floor consists entirely of lightweight partition walls.
And on the ground floor, although thinner, it’s all concrete?
Papo8801
29 Aug 2024 18:18
Oh, so the limited variety of the (previously known four) icons has finally improved? – then I should take another look when I get the chance.
And the entire ground floor, even though thinner, is made of concrete?
Yes, concrete according to the technical specifications.
Interior walls
· The ground floor interior walls are made of concrete C 25/30 with lightweight aggregate or as required by structural specifications, thickness 6.5 cm (2.6 inches), suitable for wallpapering and factory-primed (the walls must not be re-primed or treated with wallpaper primer or similar products). The walls need to be wallpapered or coated with painter’s fleece when using other wall finishes. Interior or partition walls not shown in the above technical plans are not part of our scope of supply.
Is there any reason against this?
hanse987
29 Aug 2024 18:34
A cross-section of the house would be interesting, or at least the knee wall height and the 2m (6 ft 7 in) line.
Why is the guest toilet window placed so high? I would make the window wider and higher to prevent direct visibility inside.
Why does one child's bedroom have a floor-to-ceiling window while others do not?
motorradsilke
29 Aug 2024 18:46
Papo8801 schrieb:
I was actually thinking of a coat closet under the stairs. Here’s a picture from a recently built house. You could easily build something underneath, right?
In the pantry, the washing machine and dryer. Does that work? Or should I remove the wall completely between the pantry and the utility room?
What do you mean by washing twice? The large utility room was built for that purpose, wasn’t it? Dirty clothes go straight into the washing machine and that’s it. Take off your shoes there and the hallway stays clean.
I wouldn’t put the dryer in the pantry, it gives off a lot of heat.
The issue of having the washing machine and mudroom in the same space is often criticized here by ypg. We’ve had it like that for almost three years now and it works perfectly. Without washing clothes twice. I don’t wash clothes on the floor, and the clean laundry never touches the floor either. Wash the clothes, then take them out to dry, either in the dryer or hung on racks in the utility room at the back. From the dryer or racks, fold them again and put them in the closet.
But definitely have a sink right where you enter. Being able to take off dirty shoes and wash your hands right after gardening, and to leave work clothes there immediately, is, in my opinion, perfect.
Papo8801
29 Aug 2024 19:01
hanse987 schrieb:
A cross-section through the house would be interesting, or at least the knee wall height and the 2-meter (6 ft 7 in) line.
Why is the guest WC window placed so high? I would make the window wider and higher to prevent direct views inside.
Why does one children's room have a floor-to-ceiling window while others do not?
The guest WC window is designed to let in plenty of light. It can be frosted for privacy. I actually thought that was a positive feature.
The children's rooms face the garage/carport. Therefore, they only have standard windows, not floor-to-ceiling. From an aesthetic point of view, the bathroom upstairs also only has a window. But I would need to reconsider that.
The knee wall height is 1.50 m (4 ft 11 in).
11ant29 Aug 2024 19:07
Papo8801 schrieb:
Is there any reason against that?
Yes, of course, it’s stated there:
Papo8801 schrieb:
According to the construction plan, the ground floor interior walls are made of concrete C 25/30 with lightweight aggregate or as required by structural specifications, thickness 6.5 cm (2.6 inches), suitable for wallpapering and factory-primed (the walls must not be re-primed or treated with wallpaper primer or similar products). The walls must be wallpapered or, for other wall finishes, covered with painter’s fleece.
Not “must not” but “are not allowed to” and so on. These prefabricated garage walls like typical German row house / slab construction for West Germans would be reason enough for me to look elsewhere. Your “requirements” are vague enough to allow choosing from a wide range of offers. If you’re open to a standard model house / catalog design, I’d stick with that. Please explain how you ended up choosing an Icon.
